Devices number in a REP segment
ronaldo.gama
The documentation of REP says that the convergence time in a REP segment is between 200-300ms.
What is the maximum number of the devices in REP segment for that value of convergence?
Ronaldo Gama
ankugarg
Level 3
Level 3
Hi Ronaldo,
This was checked with 32 devices in a ring...convergence should be in the specified range with this many number of devices....it may go up to 500ms if you plan to include many etherchannels(with many ports) in the topology.
B/w how many devices are you planning to put in a ring?
-Ankur
Hi Ankur,
The customer needs to enter up to 100 devices in the ring.
The solution would be to break this ring into several sub-rings, right?
Is there any documentation that lists the number of devices in the ring with the convergence time?
Ronaldo Gama
De: ankugarg
Enviada em: quarta-feira, 28 de setembro de 2011 03:00
Para: Ronaldo Gama
Assunto: - Re: Devices number in a REP segment
Cisco Support Community<>
created by Ankur Garg<> in LAN, Switching and Routing - View the full discussion<>
Hi Ronaldo,
Can you please  explain "break this ring into several sub-rings"..
Convergence should be below 250  ms for less than 64 devices in a single ring...Each ring can havce maximum 64 devices each.
