Showing results forĀ
Search instead forĀ
Did you mean:Ā
DHCP and routing problem
mohamed sebaey
Dear all
I have a big problem  , i have  a router which used as IP telephony server and this router is connected to layer 2 switch and the layer 2 switch is connected to core switch , Core switch used as a DHCP server for end users. My IP phones can not get IP address. I have my servers in vlan 10 and IP phones in vlan 4.Is there any routing issue.
router
Interface giga 0/0
IP address 10.10.10.1 255.255.255.0
switch L2
Interface gig 0/1/0                     port to router
switchport mode access
switchport access vlan 10
interface gig 0/1/49                      port to core switch
switchport mode trunk
switchport trunk encaps
core switch
IP dhcp pool voice
option 150 ip 10.10.10.1
default router 10.10.20.1
interface vlan 4
ip address 10.10.20.1 255.255.255.0
thank you
Hello
Do you have an SVI of vlan 10 on the core?
int vlan 10
ip address 10.10.10.x 255.255.255.0
vlan 10,20
exit
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
Bilal Nawaz
Hello, everything seems good here apart from your DHCP scope. And whether you have a VLAN interface on the core for VLAN 10 to allow the different subnets to communicate. After all, your phones and CME are in different subnets and need to be routed via the Core.
On your core switch, please configure the network statement and exclude any addresses that are static and being used. And also be sure you have vlan 10 configured as below:
Core switch:
Conf t
VLAN 10
VLAN 4
ip dhcp pool voice
network 10.10.20.0 255.255.255.0
interface vlan 4
interface vlan 10
ip address 10.10.10.X 255.255.255.0
Also as a gentle reminder, ip routing must be enabled on the Core (layer 3 switch) but I am assuming this is already the case.
Hope this helps
Please rate useful posts & remember to mark any solved questions as answered. Thank you.
