Dynamic inspection with DHCP snooping
Hi Experts,
I have some queries regarding DHCP snooping and Dyanmic ARP inspection.
As I have read to enable DIA , there should already be DHCP snooping enabled.
If DIA is enabled , any packet coming on any untrusted port, It checks DHCP snooping database
and if entry is exist it will forward.
So How any user  machine get ip address conneced after DIA enabled.
Thanks and regards,
Surya
cadet alain
suppose your user has got a dhcp address then it will send a discover message which is broadcast( so no need for ARP) then it will receive an offer and send out a request message( still broadcast so no need for ARP) and finally it will receive an ACK.this way the DHCP snooping binding database will get populated and then it will be able to send ARP.
Now if your user has got a static IP then you'll need to use ARP ACL:http://ccietobe.blogspot.be/2009/01/dynamic-arp-inspection-with-non-dhcp.html
You could also configure static entries in the snooping table for these static IP addresses.
Regards.
Alain
Hello
Clients on untrusted ports are to still obtain an ip address from the dhcp server with dhcp snooping and DIA enabled, as  these dhcp requests are not subject to snooping/DIA checks.
Also DIA can be used without DHCP snooping by using statically assigned filters as by default DIA will check these filters before the snooping database.
ex:
arp access-list TEST
ip arp inspection filter-list vlan xx static TEST.
I would advise you to read this exceptional post by Peter Paluch
https://supportforums.cisco.com/message/3809251#3809251
res
Paul
Please don't forget to rate any posts that have been helpful.
Thanks.
Kind Regards
Paul
