DHCP and VLAN
ottobrerosso
Hi all,
I'm trying to configure different DHCP pool on a Cisco 1841 router connected to a Cisco Catalyst 3750 switch, but DHCP seems to doesn't works...
I've created three VLAN on the switch 7-14-21 and three subinterface for FastEthernet 0/0 on router each with encapsulation dot1q referring to each  vlan, so Fa0/0.7 Fa0/0.14 Fa0/0.21 and set default router to each subinterface according to DHCP pool, but device connected to the switch don't receive IP addresses.Does anyone could help me to check this issue ? Here the configuration:
R1841#sh running-config
Building configuration...
Current configuration : 3612 bytes
version 12.4
hostname R1841
boot-start-marker
boot-end-marker
enable secret 5 $1$YL73$DZPkNN4SsF3C.4PzBmXU1/
no aaa new-model
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 10.96.8.246
ip dhcp excluded-address 10.96.8.245
ip dhcp excluded-address 10.136.12.250
ip dhcp excluded-address 10.136.12.249
ip dhcp excluded-address 10.135.100.190
ip dhcp excluded-address 10.135.100.189
ip dhcp pool LAN
network 10.96.8.0 255.255.255.248
default-router 10.96.8.246
dns-server 8.8.8.8 8.8.4.4
lease 0 8
ip dhcp pool Static-Wifi
host 10.135.100.1 255.255.255.192
client-identifier 01d4.c9ef.54d7.4b
default-router 10.135.100.190
ip dhcp pool WiFi
network 10.135.100.0 255.255.255.192
lease 0 1
ip dhcp pool Static-LAN
host 10.96.8.1 255.255.255.248
client-identifier 0178.24af.889c.a8
ip dhcp pool VLan1
network 10.10.10.0 255.255.255.0
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
vpdn enable
interface FastEthernet0/0
no ip address
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1410
no ip mroute-cache
speed 100
full-duplex
no cdp enable
interface FastEthernet0/0.7
description Default Gateway Vlan 7 - LAN / Nat Inside
encapsulation dot1Q 7
ip address 10.96.8.246 255.255.255.248
ip nat inside
no ip mroute-cache
interface FastEthernet0/0.14
description Default Gateway Vlan 14 - NAS / No Nat Inside
encapsulation dot1Q 14
ip address 10.136.12.250 255.255.255.252
interface FastEthernet0/0.21
description Sub-interface Default Gateway Vlan 21 - WiFi / Nat Inside
encapsulation dot1Q 21
ip address 10.135.100.190 255.255.255.192
ip nat inside
no ip mroute-cache
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1/0
duplex full
speed 100
interface FastEthernet0/1/1
duplex full
speed 100
interface FastEthernet0/1/2
duplex full
speed 100
interface FastEthernet0/1/3
description Trunk per Access Point WiFi
switchport mode trunk
duplex full
speed 100
interface ATM0/0/0
no ip address
no ip route-cache cef
no ip route-cache
no ip mroute-cache
atm restart timer 300
no atm ilmi-keepalive
atm pppatm link reset
bundle-enable
dsl operating-mode auto
hold-queue 224 in
interface ATM0/0/0.1 point-to-point
no ip route-cache
pvc 8/35
pppoe-client dial-pool-number 1
interface Vlan1
description Interface VLAN1
ip address 10.10.10.10 255.255.255.0
ip nat inside
no ip mroute-cache
interface Dialer0
ip address negotiated
no ip proxy-arp
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username User password 0 password
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
access-list 1 permit 10.0.0.0 0.255.255.255
dialer-list 1 protocol ip permit
control-plane
line con 0
line aux 0
line vty 0
password pwd
login
line vty 1 4
login
scheduler allocate 20000 1000
end
Configurazione Switch 3750:
Switch#sh running-config
Current configuration : 3180 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
no service dhcp
hostname Switch
no aaa new-model
switch 1 provision ws-c3750-24p
ip subnet-zero
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet1/0/1
switchport access vlan 7
shutdown
duplex full
speed 100
interface FastEthernet1/0/2
shutdown
duplex full
speed 100
interface FastEthernet1/0/3
shutdown
duplex full
speed 100
interface FastEthernet1/0/4
shutdown
duplex full
speed 100
interface FastEthernet1/0/5
shutdown
duplex full
speed 100
interface FastEthernet1/0/6
shutdown
duplex full
speed 100
interface FastEthernet1/0/7
duplex full
speed 100
interface FastEthernet1/0/8
switchport access vlan 14
shutdown
duplex full
speed 100
interface FastEthernet1/0/9
shutdown
duplex full
speed 100
interface FastEthernet1/0/10
shutdown
duplex full
speed 100
interface FastEthernet1/0/11
shutdown
duplex full
speed 100
interface FastEthernet1/0/12
shutdown
duplex full
speed 100
interface FastEthernet1/0/13
shutdown
duplex full
speed 100
interface FastEthernet1/0/14
duplex full
speed 100
interface FastEthernet1/0/15
switchport access vlan 21
shutdown
duplex full
speed 100
interface FastEthernet1/0/16
shutdown
duplex full
speed 100
interface FastEthernet1/0/17
shutdown
duplex full
speed 100
interface FastEthernet1/0/18
shutdown
duplex full
speed 100
interface FastEthernet1/0/19
shutdown
duplex full
speed 100
interface FastEthernet1/0/20
shutdown
duplex full
speed 100
interface FastEthernet1/0/21
duplex full
speed 100
interface FastEthernet1/0/22
shutdown
duplex full
speed 100
interface FastEthernet1/0/23
shutdown
duplex full
speed 100
interface FastEthernet1/0/24
description Trunk
duplex full
speed 100
interface GigabitEthernet1/0/1
shutdown
interface GigabitEthernet1/0/2
shutdown
interface Vlan1
no ip address
interface Vlan7
description Interface Vlan 7 - Management Vlan LAN
ip address 10.96.8.245 255.255.255.248
interface Vlan14
description Interface Vlan 14 - Management Vlan NAS
ip address 10.136.12.49 255.255.255.252
interface Vlan21
description Interface Vlan 21 - Management WiFi
ip address 10.135.100.189 255.255.255.192
ip default-gateway 10.96.8.246
ip classless
ip http server
control-plane
line con 0
line vty 0
password pwd
login local
line vty 1 4
no login
line vty 5 15
no login
end
Switch#
Thanks!
Your LAN DHCP pool is misconfigured.
Change this -
"network 10.96.8.0 255.255.255.248"
to -
"network 10.96.8.240 255.255.255.248"
Jon
11 Replies 11
Mark Malone
There is no requirement for layer 3 vlans on a layer 2 switch , only 1 svi is required for mgmt. purposes and reachability
on your switch turn on dhcp
no service dhcp
service dhcp
so I've to remove interface for Vlan 7-14-21 and set only Vlan 1 and to start DHCP service on 3750 switch, right ?
Hey It shouldn't be a requirement but its best practice to only have a mgmt. vlan on your layer 2 switch not multiple layer 3 ints  , your telling switch my default gateway is 10.96.8.246 but then there is a closer layer 3 ip on its switch configured in same subnet , dhcp being turned off could be causing it as well
Just trying to fix what I see wrong at first look and then if problem is still there after can look deeper and what might be the cause
vlan 1 should be a sub interface like the other as well to keep it consistent as well f0/0.1
good guide for your design
http://www.firewall.cx/cisco-technical-knowledgebase/cisco-routers/336-cisco-router-8021q-router-stick.html
You could test the fix on this easy enough by shutting vlan 7 on the switch only it will not effect traffic for that subnet then turn on dhcp and connect a device up see then if you get the ip address
HI,
issue is still there... -.-''
Here the new configuration:
Router 1841:
R1841#
R1841#sh run
Current configuration : 3812 bytes
version 12.4
hostname R1841
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp excluded-address 10.10.11.254
ip dhcp pool LAN
   lease 0 8
ip dhcp pool WiFi
   lease 0 1
ip dhcp pool WiFi-Vlan1
   network 10.10.11.0 255.255.255.0
   default-router 10.10.11.254
   lease 0 3
ip dhcp pool VLan1
vpdn enable
 ip address 10.10.11.254 255.255.255.0
 ip nat inside
 no ip mroute-cache
 speed 100
 full-duplex
 no cdp enable
 ip nat inside
 no ip mroute-cache
 ip nat inside
 no ip mroute-cache
 no ip address
 shutdown
 duplex auto
 speed auto
 duplex full
 speed 100
 duplex full
 speed 100
 duplex full
 speed 100
 duplex full
 speed 100
interface ATM0/0/0
 no ip address
 no ip route-cache
 no ip mroute-cache
 bundle-enable
 hold-queue 224 in
 no ip route-cache
 pvc 8/35
interface Vlan1
 ip nat inside
 no ip mroute-cache
interface Dialer0
 no ip proxy-arp
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp pap sent-username username password 0 password
ip http server
control-plane
line con 0
line aux 0
line vty 0
 password Cisco
 login
line vty 1 4
 login
end
R1841#
Switch 3750:
Switch#sh run
Current configuration : 2902 bytes
version 12.2
no service pad
hostname Switch
no aaa new-model
ip subnet-zero
no file verify auto
 shutdown
 duplex full
 speed 100
 shutdown
 duplex full
 speed 100
 shutdown
 duplex full
 speed 100
 shutdown
 duplex full
 speed 100
 shutdown
 duplex full
 speed 100
 shutdown
 duplex full
 speed 100
 duplex full
 speed 100
 shutdown
 duplex full
 speed 100
 shutdown
 duplex full
 speed 100
 shutdown
 duplex full
 speed 100
 shutdown
 duplex full
 speed 100
 shutdown
 duplex full
 speed 100
 shutdown
 duplex full
 speed 100
 duplex full
 speed 100
 shutdown
 duplex full
 speed 100
 shutdown
 duplex full
 speed 100
 shutdown
 duplex full
 speed 100
 shutdown
 duplex full
 speed 100
 shutdown
 duplex full
 speed 100
 shutdown
 duplex full
 speed 100
 duplex full
 speed 100
 shutdown
 duplex full
 speed 100
 shutdown
 duplex full
 speed 100
 description Trunk
 duplex full
 speed 100
 shutdown
 shutdown
interface Vlan1
 description Management Interface for VLAN 1
 ip address 10.10.11.253 255.255.255.0
ip default-gateway 10.10.11.254
ip classless
ip http server
control-plane
line con 0
line vty 0 1
 password pwd
 login local
line vty 2 4
 no login
line vty 5 15
 no login
end
Switch#
Here a show version of the Switch:
Switch#    show version
Cisco IOS Software, C3750 Software (C3750-ADVIPSERVICESK9-M), Version 12.2(25)SEA, RELEASE SOFTWARE (fc)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Wed 26-Jan-05 00:09 by antonino
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.1(19r)EA1b, RELEASE SOFTWARE (fc2)
 Switch uptime is 1 hour, 38 minutes
System image file is "flash:/c3750-advipservicesk9-mz.122-25.SEA.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750-24P (PowerPC405) processor (revision C0) with 118784K/12280K bytes of memory.
Processor board ID CAT0839N14C
Last reset from power-on
1 Virtual Ethernet interface
24 FastEthernet interfaces
2 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 00:12:43:28:C1:80
Motherboard assembly number     : 73-8312-04
Power supply part number        : 341-0029-03
Motherboard serial number       : CAT083906A0
Power supply serial number      : DTH08352UGM
Model revision number           : C0
Motherboard revision number     : B0
Model number                    : WS-C3750-24PS-S
System serial number            : CAT0839N14C
Top Assembly Part Number        : 800-21982-01
Top Assembly Revision Number    : F0
Version ID                      : N/A
Hardware Board Revision Number  : 0x09
Switch   Ports  Model              SW Version              SW Image
*    1   26     WS-C3750-24P       12.2(25)SEA             C3750-ADVIPSERVICESK
Configuration register is 0xF
Switch#
If I try to connect my pc to switch FA1/0/7 I'm not able to have an IP address from Router subinterface FA0/0.7
From the switch -
"sh int trunk"
and I assume you have connected fa01/0/24 to fa0/0 on the router ?
Jon
yes FA1/0/24 is connected to Fa0/0
Here command output:
Switch#sh int trunk
Port        Mode         Encapsulation  Status        Native vlan
Fa1/0/24    on           802.1q         trunking      1
Port      Vlans allowed on trunk
Fa1/0/24    1-4094
Port        Vlans allowed and active in management domain
Fa1/0/24    1,7,14,21
Port        Vlans in spanning tree forwarding state and not pruned
Fa1/0/24    1,7,14,21
Switch#
Change this -
to -
Jon
I've change network to 10.96.8.240 255.255.255.248 and nothing changed
I've tried to set network 10.96.8.0 255.255.255.0 and it works fine.
But checking network originally set 10.96.8.0 255.255.255.248 first address should be 10.96.8.1 last 10.96.8.6
http://mxtoolbox.com/subnet/?filter=10.96.8.0/29&source=subnettool
why it doesn't works ?
Other question after changed network to 10.96.8.0 255.255.255.0 my pc receive the IP address but it was not able to go to internet... but this topic next thread; now I've to solve DHCP.
Thanks to all for support to a student :)
Solved!!!!
It works :)
Here the correct DHCP pool configuration:
Current configuration : 3765 bytes
version 12.4
hostname R1841
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
ip dhcp excluded-address 10.135.100.62
ip dhcp excluded-address 10.96.8.6
ip dhcp pool LAN
   default-router 10.96.8.6
   lease 0 8
   default-router 10.135.100.62
ip dhcp pool WiFi
   lease 0 1
   lease 0 3
ip dhcp pool VLan1
vpdn enable
 ip nat inside
 no ip mroute-cache
 speed 100
 full-duplex
 no cdp enable
 ip address 10.96.8.6 255.255.255.248
 ip nat inside
 no ip mroute-cache
 ip address 10.136.12.3 255.255.255.252
 ip address 10.135.100.62 255.255.255.192
 ip nat inside
 no ip mroute-cache
 no ip address
 shutdown
 duplex auto
 speed auto
 duplex full
 speed 100
 duplex full
 speed 100
 duplex full
 speed 100
 duplex full
 speed 100
interface ATM0/0/0
 no ip address
 no ip route-cache
 no ip mroute-cache
 bundle-enable
 hold-queue 224 in
 no ip route-cache
 pvc 8/35
interface Vlan1
 ip nat inside
 no ip mroute-cache
interface Dialer0
 no ip proxy-arp
 ip nat outside
 encapsulation ppp
 dialer pool 1
 dialer-group 1
 ppp pap sent-username user password 0 pwd
ip http server
control-plane
line con 0
line aux 0
line vty 0
 password pwd
 login
line vty 1 4
 login
end
R1841#
Glad to hear you got it working :)
Jon
