DHCP: client-identifier/hardware-address
michal.dudzak
iam using docking station which have its own network card and i would like to staticaly bind it to ip address. It should work as whenever i connect anything to docking station it should get same fixed IP address always. However it is not working like that.
every time i connect linux client it is tied to hardware address
every time i connect windows client it is tied to client-identifier
so when i configure static dhcp pool it is working only half way.
example:
ip dhcp pool DYNADOCK
host 10.10.1.101 255.255.255.0
hardware-address 0050.b656.49b5
default-router 10.10.1.1
 this is working only for linux
client-identifier 0100.50b6.5649.b5
this is working only for windows
is there any way to bypass this problem?
8 Replies 8
Hello @michal.dudzak
This happen probably because Linux allows for a  much more deeper control level, whilst Windows dont.
For linux, you can tell the dhcp client to send the client identifier by editing dhcpclient.conf.
cat /etc/dhclient.conf
interface "eth0"
send dhcp-client-identifier 1:xx:xx:xx:xx:xx:xx;
send dhcp-lease-time 86400;
-If I helped you somehow, please, rate it as useful.-
iam sorry for late reaction i was too busy to answer, however i have tried proposed solution. I have not found anything like
interface "eth0"
in my dhcpclient.conf.
Also adding those lines have no impact on cisco device.
But i found GUI for changing settings of the network card (picture attached). I was able to send client-identifier via GUI to cisco device which finaly was succesfull and it worked.  However i have no idea which configuration file were changed and i would be glad to know that. (dhclient.conf remain untouched by it)
Can you check the file /etc/network/interfaces
Is that one changed and what was added?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
hello,
there is nothing in that file beside this:
auto lo
iface lo inet loopback
any other ideas? :)
distro is Kali Linux
Hi @michal.dudzak
 I have a Cali right here in front of me and I can see this under /etc/dhcp/
Take a look on the pic attached.
Francesco Molino
On the Cisco side, there is nothing that you can do. However, on Linux machine, you can modify dhclient.conf to send the client-identifier.
This command can be adapted to use a variable as hardware will be different from on or out of docking station.
Francesco
michal.dudzak
thank you guys iam going to try this after work tommorow and let you know
Austin Sabio
Level 4
Level 4
I am not sure if I am following here but I would suggest to make an ip reservation through dhcp server if applicable as long as the mac address is identified.
I hope this helps. Good luck!
