DHCP Configuration in Switch
nihammimm
Is this right plan to configure DHCP on Switches like 4500 series in a production Environment.
Reza Sharifi
Yes, you can configure DHCP when the switch is in production.
Hi. You could configure DHCP server on your switches but I wouldn't recommend it because it's a very basic DHCP server and it's not scalable
I would recommend to config only the "DHCP relay" feature on your switches so they will forward the DHCP packets to a centralized and dedicated DHCP server.
