DHCP in PT
chandra_rc16
Level 4
Level 4
Will PT helps to understand DHCP ?
If anyone has tried already please let me k now.
Chandu
Regards, Chandu
7 Replies 7
chandra_rc16
Level 4
Level 4
Great. I think i cannot do DHCP labs in PT.
Router1(config)#service ?
  nagle                Enable Nagle's congestion control algorithm
  password-encryption  Encrypt system passwords
  timestamps           Timestamp debug/log messages
Question:
Will i see any questions regarding DHCP in CCNA exam ?
Chandu
Regards, Chandu
if it's part of the blueprint then you may have some questions about it and you can do DHCP in PT without any problem.
Alain
Alain,
I'm not seeing any options for that.
Chandu
Regards, Chandu
the service is enabled but can't be disabled.
Just configure your DHCP pools and connect a DHCP client and it will work.
Alain
Hi Chandra,
You can configure DHCP in PT with many different ways.
First, you can turn on the DHCP service on a Server, then add pools.
Second, you can enable DHCP on a multilayer switch using the following commands:
ip dhcp pool "pool name"
network "ip-network" "subnet mask"
default-router "ip-address"
lease (Infinite or days hours minutes)
Third, you can enable DHCP on a router using the same commands as mentioned in the second way.
Khaled Omar
Regards, Khaled Omar "Please don't forget to rate useful posts"
Khaled Omar
chandra_rc16
Level 4
Level 4
Got it.
Thanks everyonen.
Chandu
Regards, Chandu
