DHCP ISSUE between WLC and Nexus 7K
Rene Paul Huet
Dear all,
I have a strange behavior between a WLC 5508 (version 7.0.116.0) and NEXUS7010.
WLC
The WLC is configured in DHCP Bridging Mode (it sends DHCP requests without change)
Nexus
The VLAN interface is configured as follows
interface Vlan501
  ip access-group acl-int-vlan501-in-1 in
  no ip redirects
  ip address 10.12.56.4/21
  ip ospf network broadcast
  ip router ospf 100 area 10.23.0.0
  hsrp 51
    preempt delay minimum 15
    priority 80
    ip 10.12.56.1
  ip dhcp relay address 10.21.16.2
  ip dhcp relay address 10.21.16.3
  no shutdown
  description - VLAN euh-wlan-bg-guest -
The "partial" ACL is as follows :
ip access-list acl-int-vlan501-in-1
  10 remark -- hsrp ----
  20 permit udp 10.12.56.0/29 224.0.0.2/32 eq 1985 log
  40 remark -- dhcp ----
  50 permit udp any eq bootpc any eq bootps log
  60 ------
The issue is :
Clients can not obtain an IP address intermittently
If I deactivates the ACL when the problem appears(when the client can not obtain an IP@) the probleme is resolved
Note: Before the WLC was connected to Catalyst 6500 and worked properly for 2 years (with same configuration)
I saw this note about differences between DHCP relay on the NEXUS7000/NXOS an Ip helper one the 6500/IOS
https://supportforums.cisco.com/docs/DOC-14753
Do you think the problem may come from the DHCP relay or ACL on the NEXUS
If someone has an idea, do not hesitate
Best regards
René
mgalazka
What version of code are you running on the N7K?
At least in some 5.x versions of NX-OS, DHCP relay will not be treated specially in control-plane.  This means that if you have drops in your class-default class in your control-plane policy, some of those drops could be DHCP that should have been relayed.  You can check this with the command:
show policy-map interface control-plane class class-default
If this is the case you can workaround it by creating a class-map in control-plane policy to match this traffic separately.
The following is a trimmed down version from this config guide on 6.x which supports DHCP in control-plane.  In 6.x they also set COS value -- you can reference the guide and include if you choose to.
http://www.cisco.com/en/US/docs/switches/datacenter/sw/6_x/nx-os/security/configuration/guide/b_Cisco_Nexus_7000_NX-OS_Security_Configuration_Guide__Release_6.x_chapter_011001.html
ip access-list copp-system-p-acl-dhcp
  permit udp any neq bootps any eq bootps
ip access-list copp-system-p-acl-dhcp-relay-response
  permit udp any eq bootps any
  permit udp any any eq bootpc
class-map type control-plane match-any copp-system-p-class-normal-dhcp
  match redirect dhcp-snoop
  match access-group name copp-system-p-acl-dhcp
class-map type control-plane match-any copp-system-p-class-normal-dhcp-relay-response
  match access-group name copp-system-p-acl-dhcp-relay-response
policy-map type control-plane copp-system-policy
  class copp-system-p-class-normal-dhcp
    police cir 680 kbps bc 250 ms conform transmit violate drop
  class copp-system-p-class-normal-dhcp-relay-response
    police cir 900 kbps bc 500 ms conform transmit violate drop
Hope this helps,
Matt
Thank you for the quick response,
Version In N7K is  5.2(3a)
No DROP in control-plane
Best regards
Matt,
We recently had a similar issue with our Nexus 7000 running 5.2(3a), the same version as the OP.  Our issue was that PXE clients would intermittently get an IP address via. DHCP.  I implemented a similar control-plane policy on our Nexus 7000 and that fixed the issue.  Thank you for your post and helping us fix our issue!
! Create ACLs to match DHCP traffic
ip access-list system-p-acl-dhcp
ip access-list system-p-acl-dhcp-relay-response
! Modify existing class-map
class-map type control-plane match-any copp-system-class-redirect
   no match redirect dhcp-snoop
! Create new class-maps
class-map type control-plane match-any system-p-class-normal-dhcp
  match access-group name system-p-acl-dhcp
class-map type control-plane match-any system-p-class-normal-dhcp-relay-response
  match access-group name system-p-acl-dhcp-relay-response
! Add new class maps into system control plane policy
class system-p-class-normal-dhcp
  police cir 1 mbps bc 500 ms conform transmit violate drop
class system-p-class-normal-dhcp-relay-response
  police cir 1 mbps kbps bc 500 ms conform transmit violate drop
! Verify DHCP traffic is now handled by the new classes with the higher CIR
show policy-map interface control-plane class system-p-class-normal-dhcp
Control Plane
  service-policy  input: copp-system-policy
    class-map system-p-class-normal-dhcp (match-any)
      police cir 1 mbps , bc 500 ms
      module 1 :
        conformed 556491 bytes; action: transmit
        violated 0 bytes; action: drop
      module 2 :
        conformed 0 bytes; action: transmit
      module 10 :
 show policy-map interface control-plane class system-p-class-normal-dhcp-relay-response
Control Plane
    class-map system-p-class-normal-dhcp-relay-response (match-any)
      module 1 :
        conformed 450674 bytes; action: transmit
      module 2 :
      module 10 :
Here’s what the default class looks like.  As you can see, there are many drops…  Should we raise the CIR on this class to prevent other issues?
Control Plane
    class-map class-default (match-any)
      police cir 100 kbps , bc 250 ms
      module 1 :
        conformed 17379304 bytes; action: transmit
        violated 36271565 bytes; action: drop
      module 2 :
        conformed 106658 bytes; action: transmit
        violated 963 bytes; action: drop
      module 10 :
