DHCP issue - Cisco 3750X series switch
Issue:
DHCP is not working in my network between two different vlans even after configuring ip helper-address in the switch. Provided below the configuration of switch. Please help to identify the problem:
DHCP Server is part of vlan 100, primary - x.y.112,141 and secondary - x.y.112.142.
XYZABCDMZ-SW2#sh run
Building configuration...
Current configuration : 24037 bytes
version 12.2
no service pad
service tcp-keepalives-in
service timestamps debug datetime msec show-timezone
service timestamps log datetime msec show-timezone
service password-encryption
hostname XYZABCDMZ-SW2
boot-start-marker
boot-end-marker
logging buffered 5000 informational
aaa new-model
 --More--         !
aaa authentication login default group tacacs+ local
aaa authentication login LOCAL local
aaa authentication dot1x default group radius
aaa authorization exec default group tacacs+
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa session-id common
clock timezone gmt -6
clock summer-time GMT recurring
switch 2 provision ws-c3750x-48
system mtu routing 1500
authentication mac-move permit
no ip subnet-zero
no ip source-route
no ip domain-lookup
ip domain-name XYZABC.com
dot1x system-auth-control
spanning-tree mode rapid-pvst
spanning-tree loopguard default
spanning-tree portfast bpduguard default
spanning-tree etherchannel guard misconfig
spanning-tree uplinkfast
spanning-tree backbonefast
errdisable recovery cause udld
errdisable recovery cause bpduguard
errdisable recovery cause channel-misconfig (STP)
errdisable recovery cause pagp-flap
errdisable recovery cause dtp-flap
 --More--         errdisable recovery cause link-flap
errdisable recovery cause sfp-config-mismatch
errdisable recovery cause gbic-invalid
errdisable recovery cause dhcp-rate-limit
errdisable recovery cause storm-control
errdisable recovery cause arp-inspection
errdisable recovery cause loopback
errdisable recovery interval 30
vlan internal allocation policy ascending
vlan dot1q tag native
interface Port-channel1
 switchport mode trunk
interface FastEthernet0
 no ip address
 no ip route-cache
 no ip mroute-cache
 shutdown
 --More--         !
interface GigabitEthernet2/0/1
 switchport access vlan 10
 switchport mode access
 switchport nonegotiate
 switchport port-security
 switchport port-security violation restrict
 storm-control broadcast level 3.00
 storm-control multicast level 3.00
 spanning-tree guard root
interface GigabitEthernet2/0/2
 shutdown
 authentication port-control auto
 dot1x pae authenticator
 --More--         spanning-tree portfast
interface GigabitEthernet2/0/43
interface GigabitEthernet2/0/44
interface GigabitEthernet2/0/45
 shutdown
interface GigabitEthernet2/0/46
 switchport access vlan 100
interface GigabitEthernet2/0/47
 --More--         interface GigabitEthernet2/0/48
interface GigabitEthernet2/1/1
 description XYZABCDMZ-SW1
interface GigabitEthernet2/1/2
 shutdown
interface GigabitEthernet2/1/3
 description XYZABCDMZ-SW2
interface GigabitEthernet2/1/4
 shutdown
interface TenGigabitEthernet2/1/1
 --More--         interface TenGigabitEthernet2/1/2
interface Vlan1
 no ip address
 no ip route-cache
 no ip mroute-cache
 shutdown
interface Vlan10
 ip address x.y.116.19 255.255.252.0
 ip helper-address x.y.112.142
 ip helper-address x.y.112.141
 no ip route-cache
 no ip mroute-cache
interface Vlan100
 ip address x.y.112.151 255.255.255.192
 no ip route-cache
 no ip mroute-cache
ip default-gateway x.y.116.1
ip classless
no ip http server
 --More--         ip http secure-server
ip sla enable reaction-alerts
logging x.y.116.144
logging x.y.112.144
access-list 1 permit x.y.112.144
access-list 4 permit x.y.112.142
tacacs-server timeout 30
--More--         !
line con 0
 exec-timeout 5 0
 logging synchronous
 login authentication LOCAL
line vty 0 4
 access-class 1 in
 exec-timeout 5 0
 logging synchronous
 transport input ssh
line vty 5 15
 exec-timeout 5 0
 logging synchronous
 transport input ssh
monitor session 1 source interface Gi2/0/47
monitor session 1 destination interface Gi2/0/43
monitor session 2 source interface Gi2/0/48
monitor session 2 destination interface Gi2/0/44
ntp clock-period 36026795
ntp server x.y.94.11
end
 --More--
XYZABCDMZ-SW2#      exi
acampbell
There are many reasons why this may not be working.
Have you looked at the DHCP server itself.
Can it ping the vlan 100 & 10  addresses
Have the scopes been set set up correctly
Alex
Regards, Alex. Please rate useful posts.
It might be helpful if the originl poster would post the output of show vlan from the switch.
Rick
Rick
