DHCP Lease
md_ani
I want to provide permanent IP Address to the client computer thats why I have given lease 365 days in DHCP Pool. Problem is that some times IP got changes after 1 or 2 days. Sometimes there are IP conflicts in the Network. Belo is the Configuration.
ip dhcp pool TEST-DHCP
network 172.18.100.0 255.255.252.0
default-router 172.18.100.1
lease 365
Pls help me to provide permanet IP Address and resolvong IP Conflicts.
Anis
paddyxdoyle
Level 6
Level 6
I think you need to create an manual binding on your router based on your clients IP address and MAC address.
Have a look through the following link which explains how to achieve this:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca75c.html
Plus you need to add the following command to stop your router from leasing out the IP address of your default-router and thus causing ip conficts
ip dhcp excluded-address 172.18.100.1
Good luck
Paddy
