Gigastack of Catalyst Switches
c-tai
Are the gigastacks "hot-swappable"? Someone told me that gigastacks are not hot swappable and that I should power down the switch before inserting and removing the gigastack... is that correct?
Thanks!
all GBICs, also the Gigastack GBICs, are hot-swappable.
Check this link:
System Requirements to Implement Gigabit Ethernet on Catalyst Switches
Prerequisites
http://www.cisco.com/en/US/partner/tech/tk389/tk214/technologies_tech_note09186a0080094863.shtml#prereq
HTH,
GP
I'm pretty sure it depends on the switch. I've always been told by TAC that hot swappable gbics are not supported on the 3500 platform for example.
