DHCP limitation on cisco 3750 switches
Dhaval Dikshit
I want to clear following things regarding Cisco 3750 switch.
1. Can I configure Multiple DHCP pool on C3750?
2. Performance effect due to same?
3. Can I resrve IP addrese from DHCP pool for specific MAC address.
4. Can I Exempt IP address from DHCP pool ?
Please share useful link for same.
Dhaval Dikshti
Peter Paluch
Hello Dhaval,
Yes, you can, provided that each DHCP pool is tied to a different IP network. You simply create multiple pools distinguished by their unique names, and assign each pool to a particular network using the usual network command.
Performance impact is negligible, as the DHCP is used only when stations acquire their IP settings. There would have to be hundreds, if not thousands of stations requesting DHCP communication in order for the performance impact to be measurable. With sensible lease times in orders of hours, you will not notice any increased load.
Yes, that is possible, although the configuration is awkward. Check the following two documents (actually, it's just a single document with two sections relevant to your question):
http://www.cisco.com/en/US/docs/ios-xml/ios/ipaddr_dhcp/configuration/12-4t/config-dhcp-server.html#GUID-68D87544-7C6F-48C9-9DFE-56F5B7E4A89D
http://www.cisco.com/en/US/docs/ios-xml/ios/ipaddr_dhcp/configuration/12-4t/config-dhcp-server.html#GUID-BCEB43D4-8C44-4C86-BBAA-6B977196D35C
The configuration examples can also be found later in the same document.
Yes, you can. This is done using the ip dhcp excluded-address command in the global configuration mode (i.e. this command is not entered in any particular DHCP pool). More information can be found here:
http://www.cisco.com/en/US/docs/ios-xml/ios/ipaddr_dhcp/configuration/12-4t/config-dhcp-server.html#GUID-9DFE5A79-4529-4DD9-BB7B-CB46C10E9ABE
Best regards,
Peter
5 Replies 5
Peter Paluch
Hello Dhaval,
Best regards,
Peter
Thanks Peter,
Most of my doubt are clear. Just want to know that how to configure PAC or WPAD string in DHCP?  Is it same option which we use in ASA ? i.e.
dhcpd option 252 ascii http://example/example.pac interface inside
or its differant ?
Thanks & Regards,
Dhaval
Hello Dhaval,
Specifying DHCP options in IOS is very similar: in each pool where the option is necessary, you use the following command:
Best regards,
Peter
Thanks a lot Peter.
Dhaval
Hi Dhaval,
You are welcome!
Best regards,
Peter
