DHCP not recieved by host
arun.stha
L3 Switch as dhcp:
ip dhcp pool wifi_pool_1
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.1
   dns-server 192.168.0.180
ip access-list extended LAN_ONLY
permit ip 192.168.10.0 0.0.0.255 192.168.0.0 0.0.255.255
interface Vlan20
ip address 192.168.10.1 255.255.255.0
I want to block internet to  host connected to AP and only permit the internal network, my internal network are in range of 192.168.0.0/16, ACL was created as above, but the host that connects to AP arent able to obtain ip address provided by DHCP.
IP is obtain by host if i put ace as "permit ip any any"  but this is not my requirement because this leads host to access internet also.
you could add the following line to your ACL to generally allow DHCP-traffic:
permit udp any eq bootpc any eq bootps
It could be more specific but this line is quite often used for that task.
EDIT: Cadets Solution is more specific and though better then mine ... ;-)
Don't stop after you've improved your network! Improve the world by lending money to the working poor:
http://www.kiva.org/invitedby/karsteni
cadet alain
Do this:
permit udp any eq bootpc  host 255.255.255.255 eq bootps
permit udp any eq bootpc  host 192.168.10.1 eq bootps
Regards.
Alain
arun.stha
Thank you, cadet and Karsten both of u, It worked well.
