DHCP not serve IP
Adrian Ardelean
I configured an DHCP server with Static Mapping, but I don't get IPs on clients.
I have:
ip dhcp pool IT
origin file flash1:dhcp-it.txt
domain-name domain.com
dns-server 172.16.5.2 172.16.5.26
default-router 172.16.0.1
...and the txt file:
*time* Mar 14 2012 11:30 AM
*version* 1
! IP address      Type      Hardware address        Lease expiration
172.16.0.2 /27    ID          0100.19b9.6128.e4      1
... and so on
On debug I got:
...DHCPD: No option 125
What did i do wrong?
Thank you!
16 Replies 16
cadet alain
can you try restarting the dhcp service:
no service dhcp
service dhcp
Have you done this  ?  :
"The  static mapping text file can be copied to flash memory on the router  and served by the routers tftp process. In this case, the IP address in  the origin file line must be an address owned by the router and one  additional line of configuration is required on the router:
tftp-server flash staticfilename"
Regards.
Alain
Excuse me but was in a vacation.
Not working, but you were right with the quote.
There is a change after configuring the tftp:
Loading dhcp-it.txt from 172.16.0.1 (via GigabitEthernet0/0): !
[OK - 181 bytes]
I also restarted the dhcp service but the same:
Mar 27 08:50:23.701: DHCPD: DHCPDISCOVER received from client 0100.1c23.3541.98 on interface GigabitEthernet0/0.
Mar 27 08:50:27.697: DHCPD: client's VPN is .
Mar 27 08:50:27.697: DHCPD: No option 125
..and looping.
The text file is:
router1#more flash1:dhcp-it.txt
*version* 1
!IP address     Type    Hardware address        Lease expiration
172.16.0.3 /27  ID      0100.1c23.3541.98               1
*end*
...and the exact configuration is:
ip dhcp pool IT
origin file tftp://172.16.0.1/dhcp-it.txt
Any ideeas?
Thanks!
Hey Friend,
Can you please let me know if the same works with using the network command :
Example :
Router(config)# ip dhcp excluded-address 172.16.5.2
ip dhcp excluded-address 172.16.5.26
ip dhcp excluded-address 172.16.5.1
serve dhcp
ip dhcp pool IT
network 172.16.5.0 255.255.0.0
Waiting for your revert !!
Yes it's working. It gives me an IP.
debug:
Mar 27 10:06:56.583: DHCPD: DHCPREQUEST received from client 0100.1c23.3541.98.
Mar 27 10:06:56.583: DHCPD: Using hostname 'IT-Adi.icepronav.ro' for dynamic update (from FQDN option)
Mar 27 10:06:56.583: DHCPD: Sending DHCPACK to client 0100.1c23.3541.98 (172.16.0.3).
Mar 27 10:06:56.583: DHCPD: no option 125
Mar 27 10:06:56.583: DHCPD: ARP entry exists (172.16.0.3, 001c.2335.4198).
Mar 27 10:06:56.583: DHCPD: broadcasting BOOTREPLY to client 001c.2335.4198.
THAT MEANS .. your static mapping is not working !!
Please check the config for the mapping once again..
I can figure that...
The exact configuration is 3 post ahead.
I don't know what I am missing
can you paste the file text here ?
*version* 1
*end*
Adrian,
Can you try changing Lease Expiration to "Infinite" - without qoutes ??
regards,
Parvesh
Did that, no success
any updates or changes in the behaviour/debug after changing the lease expriation ?
No, I got the same:
Mar 27 10:47:43.707: DHCPD: DHCPDISCOVER received from client 0100.1c23.3541.98 on interface GigabitEthernet0/0.
Mar 27 10:48:00.067: DHCPD: client's VPN is .
Mar 27 10:48:00.067: DHCPD: No option 125
Adrian Ardelean
Strange is that on sh ip dhcp binding I got:
Bindings from all pools not associated with VRF:
IP address          Client-ID/              Lease expiration        Type
                    Hardware address/
                    User name
172.16.0.2/27       0100.19b9.6128.e4       Infinite                Static
172.16.0.3/27       0100.1c23.3541.98       Infinite                Static
...so it reads the origin file...
It means the lease is being assigned .. what about the ip being received at the hosts .... any update ??
regards,
Parvesh
