DHCP not working
adamt_
DHCP isn't working on the right side of the network. Password everywhere is either class or cisco. I'm really new to DHCP so i would appreciate any help!
there is no IOS or external DHCP server configured. Below the configs where the routers themselves are the DHCP servers. Make the changes marked in bold. Revised Packet Tracer project file is attached:
adam#sh run
Building configuration...
Current configuration : 1120 bytes
version 12.2
no service timestamps log datetime msec
no service timestamps debug datetime msec
service password-encryption
hostname adam
enable secret 5 $1$mERr$9cTjUIEqNGurQiFU.ZeCi1
--> ip dhcp excluded-address 192.168.34.1
--> ip dhcp pool LAN
--> network 192.168.34.0 255.255.255.0
--> default-router 192.168.34.1
--> dns-server 8.8.8.8
ip cef
no ipv6 cef
interface FastEthernet0/0
ip address 192.168.34.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet1/0
ip address 193.168.1.1 255.255.255.0
duplex auto
speed auto
interface Serial2/0
no ip address
clock rate 2000000
shutdown
interface Serial3/0
no ip address
clock rate 2000000
shutdown
interface FastEthernet4/0
no ip address
shutdown
interface FastEthernet5/0
no ip address
shutdown
--> no router rip
ip classless
--> ip route 192.168.1.0 255.255.255.0 193.168.1.2
ip flow-export version 9
banner motd ^Ceaew^C
line con 0
password 7 0822455D0A16
login
line aux 0
line vty 0 4
login
line vty 5 15
login
end
Router0#sh run
Current configuration : 939 bytes
version 12.2
hostname Router0
--> ip dhcp excluded-address 192.168.1.1
--> network 192.168.1.0 255.255.255.0
--> default-router 192.168.1.1
ip cef
no ipv6 cef
ip address 193.168.1.2 255.255.255.0
duplex auto
speed auto
duplex auto
speed auto
interface Serial2/0
no ip address
clock rate 2000000
shutdown
interface Serial3/0
no ip address
clock rate 2000000
shutdown
no ip address
shutdown
no ip address
shutdown
ip classless
--> ip route 192.168.34.0 255.255.255.0 193.168.1.1
line con 0
line aux 0
line vty 0 4
login
end
adam#sh run
version 12.2
hostname adam
ip cef
no ipv6 cef
duplex auto
speed auto
duplex auto
speed auto
interface Serial2/0
no ip address
clock rate 2000000
shutdown
interface Serial3/0
no ip address
clock rate 2000000
shutdown
no ip address
shutdown
no ip address
shutdown
--> no router rip
ip classless
line con 0
login
line aux 0
line vty 0 4
login
line vty 5 15
login
end
Router0#sh run
version 12.2
hostname Router0
ip cef
no ipv6 cef
duplex auto
speed auto
duplex auto
speed auto
interface Serial2/0
no ip address
clock rate 2000000
shutdown
interface Serial3/0
no ip address
clock rate 2000000
shutdown
no ip address
shutdown
no ip address
shutdown
ip classless
line con 0
line aux 0
line vty 0 4
login
end
Thanks a lot! It's working now!
