DHCP on 3825 for Specific VLAN
Scott Hanson
Level 3
Level 3
Hello all,
I am trying to configure a 3825 as a DHCP server but I only want it to hand out IP addresses to clients on a specific VLAN.  Is that possible and if so can someone send me a link?
Thanks in advance!  Replies rated.
8 Replies 8
cadet alain
just create a scope for the specific subnet of that VLAN and also if other subnets(VLANs), don't forget to add a route for the IP address of the DHCP relay interface on that VLAN because the router will send a unicast offer  to the Relay agent which then will unicast or broadcast the offer.
Alain
John Blakley
Are the vlans on a l3 switch that you're routing for, or is this router configured as router on a stick?
If you have a l3 switch, you'd create your dhcp server on the router and then point the svi to the router to pull addresses from:
On the router:
ip dhcp excluded-address 192.168.10.1-192.168.10.99
ip dhcp pool ForVLAN10
network 192.168.10.0
default-router 192.168.10.5
dns-server 4.2.2.1
On L3 Switch:
int vlan 10
ip address 192.168.10.5 255.255.255.0
ip helper-address 192.168.1.1 <---router address
The request will match the 192.168.10.0/24 subnet.
If you have it configured on the router with subinterfaces for router-on-a-stick:
dns-server 4.2.2.1
int fa0/0
int fa0/0.10
encapsulation dot1q 10
ip addres 192.168.10.1 255.255.255.0
You won't have to do anything more other than add the dhcp pool at the top.....
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
the switches are Layer 2.  Are you both saying I need to configured the DHCP on the router?  I can do that no problem.  How do I restrict it into only handing out IP addresses for that 1 particular VLAN?
how is your dhcp server configured and what device is this ? what is your topology ?
Alain
per the problem description I would like to make a 3825 router the DHCP server.  That router is plugged into a 2960 switch that is part of a stack.  I have LWAPs hanging off trunk ports on the switches.  My goal is to make 1 particular SSID an "Internet Only" SSID so that it gets an IP address from the router instead of the internal DHCP server.  I also want to segment the traffic as "Internet Only" so that they don't touch the Internals network.
Scott,
Do you currently have subinterfaces configured on the router now to support your vlans?
HTH,
John
Hello JOhn,
I do curently have sub-interfaces.  I configured a new one for this "Internet-Only" VLAN
Okay. All you need to do then is create a pool that corresponds to your subinterface that you want users to be able to get the address from like in my first post.
dns-server 4.2.2.1
int fa0/0
int fa0/0.10
Your other users will land on an interface that probably has a helper configured on the interface for the other vlans minus the one that your dhcp server is actually on.
HTH,
John
