DHCP on outside interface with NAT
sngrindrod
Community Member
What "IP NAT POOL" is used if my outside interface has an IP of DHCP.  Im using a 2611 with 12.4(25c).  IOS will only allow an actual IP.
9 Replies 9
Reza Sharifi
Do a "sh ip arp" an the NAT router.  That should tell you the IP address you are using.
Jon Marshall
Simon
Do you mean to NAT your internal devices so they can get to the internet ?  I'm assuming so because you mention using a NAT pool.
If so you shouldn't need to know the IP and indeed it could change anyway. Would this config not work  -
access-list 101 permit ip any any  <-- note you can replace the first "any" with the specific 192.168.x.x addresses if you want
ip nat inside source list 101 interface fa0/0 overload
If i have misunderstood then let me know.
Jon
Ref page 676 Sybex CCNA Study Guide.
ip nat pool globalnet ???.???.???.???  ???.???.???.??? (im using dhcp from the isp, Cisco IOS will not allow "dhcp". this sis where I'm stuck)
netmask 255.255.255.0
ip nat inside source list 1 pool globalnet overload
int f0/0
ip address dhcp
ip nat outside
int f0/1
ip address 192.168.2.1 255.255.255.252
ip nat inside
int s0/0
192.168.2.6 255.255.255.252
ip nat inside
access-list 1 permit any any
Thanks for your help
Si
sigrindrod@knology.net
Do as jon suggested, don't use the nat pool command and specify the interface instead in the ip nat inside source command.Even if you knew the IP address, when you receive a new one from DHCP it will stop working if you use the nat pool command.
Regards.
Alain
I'm using this and it's working fine :
interface GigabitEthernet1
description External interface with DHCP
ip address dhcp
ip nat outside
negotiation auto
interface GigabitEthernet2
description Trunk interface
no ip address
negotiation auto
interface GigabitEthernet2.111
description Vlan 111
encapsulation dot1Q 111
ip address 192.168.111.1 255.255.255.0
ip nat inside
interface GigabitEthernet2.121
description Vlan 121
encapsulation dot1Q 121
ip address 192.168.121.1 255.255.255.0
ip nat inside
interface GigabitEthernet2.131
description Vlan 131
encapsulation dot1Q 131
ip address 192.168.131.1 255.255.255.0
ip nat inside
interface GigabitEthernet2.141
description Vlan 141
encapsulation dot1Q 141
ip address 192.168.141.1 255.255.255.0
ip nat inside
interface GigabitEthernet3
no ip address
shutdown
negotiation auto
ip nat inside source list 100 interface GigabitEthernet1 overload extended
ip forward-protocol nd
no ip http server
no ip http secure-server
access-list 100 remark NAT DHCP Access-list
access-list 100 permit ip 192.168.111.0 0.0.0.255 any log
access-list 100 permit ip 192.168.121.0 0.0.0.255 any log
access-list 100 permit ip 192.168.131.0 0.0.0.255 any log
access-list 100 permit ip 192.168.141.0 0.0.0.255 any log
Thanks for sharing your experience. I am glad that this is working fine for you. I do have a couple of comments about the access list you are using. I have seen some odd things happen when an access list that is used for something other than access-group and includes the log parameter. (the log parameter works well when the access list is applied with access-group but some times not well when the access list is used some other way). Also I know that the original discussion did suggest using an extended access list, but I have seen some unexpected behaviors when an extended access list used for address translation specified any as the destination. Your access list is not looking for any destination addresses and is not looking for any protocol ports and so there is no benefit from using an extended access list for your address translation. I wold suggest that you rewrite the access list and use a standard acl.
Rick
Will consider that, thanks!
Note that I avoided something more simple as need to connect from the outside to the external IP, like for ssh, and although not specifying dest/services, that will be ready for that later.
What you did mentioned about log not working all times... does it affect NAT process or only does not log all the times?
I am concerned about the possibility that NAT could be affected.
I do not understand your comment about "although not specifying dest/services, that will be ready for that later."  Are you suggesting that you do have plans to change and to not translate for certain destinations or for certain protocol ports?
Rick
Yes. I used that config to solve current need and future ones.
As a simple change could be done only at ACL level and dont have to go thru a complete config analisys, create a new acl to the replace the one in use at nat statement, etc.
I know that in the field thats being used in a daily basis but thats also something that leads to leave more and more trash in configs that always require further cleanup.
In my configs I always plan how to keep it for long term use, managed by others and also considering 3rd parties automation tools.
But if the log or acl type have caveats that impacts on the NAT process, thats might be a bug issue or IOS should not allow us to use that way.
