DHCP Problem (Router hang)
defash
I have the following problem, I implemented DHCP on router 3745, 3725 but once in two days the router hangs . The IOS on the router is:
c3745-adventerprisek9-mz.123-18.bin
Also I have the following config:
ip cef
ip dhcp excluded-address 172.19.255.0 172.19.255.254
ip dhcp pool Buz
network 172.19.0.0 255.255.0.0
default-router 172.19.0.1
dns-server 198.6.1.1
ip name-server 198.6.1.1
no ftp-server write-enable
interface FastEthernet0/0
ip address 203.195.158.1XX 255.255.255.240
ip nat outside
duplex full
speed 100
interface FastEthernet0/1
ip address 172.19.0.1 255.255.0.0
ip nat inside
duplex full
speed 100
interface FastEthernet1/0
ip classless
ip route 0.0.0.0 0.0.0.0 203.195.158.1x9
ip http server
ip nat inside source list 1 interface FastEthernet0/0 overload
access-list 1 permit 172.19.0.0 0.0.255.255
Can you elaborate as to what do you mean by router hangs. What symptoms do you see in the router during this time? Though the router mayn't assign an address that's configured on one of it's interfaces, it's generally a good practice to exclude the router's IP (172.19.0.1) from the DHCP pool.
