Catalyst 2960 - Send SPAN / RSPAN traffic to same port
kcook73
I have two 2960's connected with a trunk (i.e. cross connect on Gi0/1 on both switches). I have two ports on each switch (four total) that I am trying to monitor with SPAN/RSPAN on one port / one switch. I can get SPAN to work (send traffic from two source ports on switch 1 to destination port on switch 1); I can also get RSPAN to work (send traffic from two source ports on switch 2 to destination port on switch 1). However, I cannot get both of these to work at the same time - i.e. send SPAN traffic on switch 1 and RSPAN traffic on switch 2 all to a single destination port on switch 1. Any suggestions?
sachinraja
Level 9
Level 9
I'm really not sure if this will work.. Just see the following URL for the guidelines for SPAN and RSPAN...
http://www.cisco.com/en/US/products/hw/switches/ps708/products_configuration_guide_chapter09186a008007e6fa.html#wp1042096
On the RSPAN parameters, u need to have the ports on the RSPAN VLANs.. not really sure if this VLAN can take the SPAN traffic.. Will check further and let u know.
Raj
amit-singh
Level 8
Level 8
You cannot have a single destination port for both the SPAN and RSPAN session on the 2960's. This is a destination port restriction on the switch. You can have 2 different session with 2 different destination ports and that too with in the SPAN/RSAPN configuration restrictions. Please check the link above posted by Raj for the same restrictions.
HTH,Please rate if it does.
-amit singh
I decided to move the SPAN traffic of both switches to a third switch that is already connected to both - then all traffic is RSPAN and can use a single destination port. My limitation is an IDS server with a single inspection port.
I think that should work in this case. Make sure that you have RSPAN configured on both the switches with source interfaces/vlans and RSPAN vlans and bring this traffic to the third switch where you have destination port connected. this should work in this case.
-amit singh
