DHCP RAW options 15
noliveira
I've been trying to configure a DHCP option 15 on a 3650 switch running XE 16.3.5b but I'm getting this error:
STACK(dhcp-config)#option 15 ascii domain.co.uk
% DHCP does not allow raw option 15.
STACK(dhcp-config)#
Does anyone know what could be the issue?
Many thanks
Mark Malone
Just tested this on slightly newer16.3.7 denali to see incase was bug but just looks like that option is not supported , if i do other options it works fine
xxxxxxxxx(config)#ip dhcp pool Msrk
xxxxxxxxx(dhcp-config)#op
xxxxxxxxx(dhcp-config)#option 15 as
xxxxxxxxx(dhcp-config)#option 15 ascii domain.co.uk
xxxxxxxxx(dhcp-config)#option 67 ascii domain.co.uk
xxxxxxxxx(dhcp-config)#do sh ver | i 16.3
Cisco IOS Software [Denali], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.3.7, RELEASE SOFTWARE (fc4)
* 1 52 WS-C3650-48PS 16.3.7 CAT3K_CAA-UNIVERSALK9 INSTALL
xxxxxxxxx(dhcp-config)#option 36 ascii domain.co.uk
xxxxxxxxx(dhcp-config)#option 112 ascii domain.co.uk
Works fine on this image must be a bug in denali ...
(config)#ip dhcp pool MARK
(dhcp-config)#network
cat3k_caa-universalk9.SPA.03.06.07b.E.152-2.E7b.bin"
