ILP:: Inline power process coredump for switch
Hi all,
I am investigating POE issues on a 3850 stack, and i notice some things while troubleshooting
Switch Ports Model              SW Version        SW Image              Mode
     1 56    WS-C3850-48P       03.03.03SE        cat3k_caa-universalk9 INSTALL
*    2 56    WS-C3850-48P       03.03.03SE        cat3k_caa-universalk9 INSTALL
I have some debugging active.
ILPOWER:
  ILPOWER event debugging is on
  ILPOWER controller debugging is on
I see in the logs the following message
021030: Nov 14 2014 11:05:01.185 CET: ILP:: Inline power process coredump for switch 2
021034: Nov 14 2014 11:05:06.841 CET: ILP:: Inline power process coredump for switch 1
021041: Nov 14 2014 11:05:11.188 CET: ILP:: Inline power process coredump for switch 2
021048: Nov 14 2014 11:05:16.872 CET: ILP:: Inline power process coredump for switch 1
021049: Nov 14 2014 11:05:21.198 CET: ILP:: Inline power process coredump for switch 2
021065: Nov 14 2014 11:05:27.002 CET: ILP:: Inline power process coredump for switch 1
021079: Nov 14 2014 11:05:31.209 CET: ILP:: Inline power process coredump for switch 2
021080: Nov 14 2014 11:05:36.873 CET: ILP:: Inline power process coredump for switch 1
021093: Nov 14 2014 11:05:41.219 CET: ILP:: Inline power process coredump for switch 2
It seems its a proces as each of the stackmember logs this message every 10seconds.
I have  search-engined this message, but to no avail,
i dont think this is a software crash as i dont have any crashfiles on the system.
What process generates these messages and why, how to troubleshoot this.
thank you in advance.
With kind regards,
Thijn van der Schoot.
chris.kruslicky
I'm seeing the same thing with a brand new cat9300 in a stack.  No PoE devices work on switch 3 but moved to switch 2 they work.
429897: May 16 08:17:02.862 EDT: ILP:: Rx Response ILP msg: response_code 14, sw_num 2
429898: May 16 08:17:02.862 EDT: ILP:: ILP msg: received E_ILP_GET_DEBUG_CORE_DUMP
429899: May 16 08:17:02.862 EDT: ILP:: Inline power process coredump for switch 2
429900: May 16 08:17:04.318 EDT: ILP:: Rx Response ILP msg: response_code 16, sw_num 1
429901: May 16 08:17:04.318 EDT: ILP:: ILP msg: received E_ILP_POST
429902: May 16 08:17:04.319 EDT: ILP:: Rx Response ILP msg: response_code 12, sw_num 1
429903: May 16 08:17:04.319 EDT: ILP:: ILP msg: received E_ILP_GET_POWER_SENSE
429904: May 16 08:17:04.319 EDT: ILP:: ILP:pwr_sense: num_ports: 48, switch_num: 1
429905: May 16 08:17:04.319 EDT: ILP:: ILP:Gi1/0/3:power real 4414, min 3855, max 4638, police 0, overdraw: 0
429906: May 16 08:17:04.319 EDT: ILP:: ILP:Gi1/0/5:power real 3855, min 1899, max 4414, police 0, overdraw: 0
429907: May 16 08:17:04.319 EDT: ILP:: ILP:Gi1/0/11:power real 4292, min 2402, max 4622, police 0, overdraw: 0
429908: May 16 08:17:04.319 EDT: ILP:: ILP:Gi1/0/12:power real 4125, min 3735, max 4237, police 0, overdraw: 0
429909: May 16 08:17:04.319 EDT: ILP:: ILP:Gi1/0/13:power real 4181, min 2341, max 4292, police 0, overdraw: 0
429910: May 16 08:17:04.320 EDT: ILP:: ILP:Gi1/0/18:power real 3516, min 3237, max 3962, police 0, overdraw: 0
429911: May 16 08:17:04.320 EDT: ILP:: ILP:Gi1/0/23:power real 3628, min 2288, max 4074, police 0, overdraw: 0
429912: May 16 08:17:04.320 EDT: ILP:: ILP:Gi1/0/25:power real 3907, min 1841, max 4521, police 0, overdraw: 0
429913: May 16 08:17:04.773 EDT: ILP:: Rx Response ILP msg: response_code 14, sw_num 1
429914: May 16 08:17:04.773 EDT: ILP:: ILP msg: received E_ILP_GET_DEBUG_CORE_DUMP
429915: May 16 08:17:04.773 EDT: ILP:: Inline power process coredump for switch 1
429916: May 16 08:17:05.065 EDT: ILP:: Rx Response ILP msg: response_code 16, sw_num 3
429917: May 16 08:17:05.065 EDT: ILP:: ILP msg: received E_ILP_POST
429918: May 16 08:17:05.066 EDT: ILP:: Rx Response ILP msg: response_code 12, sw_num 3
429919: May 16 08:17:05.066 EDT: ILP:: ILP msg: received E_ILP_GET_POWER_SENSE
429920: May 16 08:17:05.066 EDT: ILP:: ILP:pwr_sense: num_ports: 48, switch_num: 3
429921: May 16 08:17:05.621 EDT: ILP:: Rx Response ILP msg: response_code 14, sw_num 3
429922: May 16 08:17:05.621 EDT: ILP:: ILP msg: received E_ILP_GET_DEBUG_CORE_DUMP
429923: May 16 08:17:05.621 EDT: ILP:: Inline power process coredump for switch 3
429924: May 16 08:17:07.097 EDT: ILP:: Sending icutoff current msg to slot:1 port:5
Power stack name: Powerstack-1
Stack mode: Power sharing
Stack topology: Ring
Switch 3:
Power budget: 1787
Power allocated: 255
Low port priority value: 21
High port priority value: 12
Switch priority value: 3
Port 1 status: Connected
Port 2 status: Connected
Neighbor on port 1: Switch 2 - c4b3.6a42.6400
Neighbor on port 2: Switch 1 - 0087.6401.1800
Switch 1:
Power budget: 1868
Power allocated: 307
Low port priority value: 20
High port priority value: 11
Switch priority value: 2
Neighbor on port 1: Switch 3 - 70c9.c6ba.e500
Neighbor on port 2: Switch 2 - c4b3.6a42.6400
Switch 2:
Power budget: 1815
Power allocated: 283
Low port priority value: 22
High port priority value: 13
Switch priority value: 4
Neighbor on port 1: Switch 1 - 0087.6401.1800
Neighbor on port 2: Switch 3 - 70c9.c6ba.e500
Hello Chris,
I see you have core dumps messages for both switch 1 and switch 3.
Is POE working on switch 1? Because you have written that you have moved devices from switch3 to switch2 and switch2 provides POE.
In any case this should be a SW bug I would recommend opening a ticket with Cisco TAC.
another option being POE a so low level service is that of trying to reboot switch3 for example to see if after reload the message of core dump disappear.
Hope to help
Giuseppe
