DHCP Relay on 3560
Sinclair_Cisco
Would like to impliment VLAN's on
Cisco IOS Software, C3560 Software (C3560-IPSERVICES-M), Version 12.2(25)SEB4
But I need a DHCP Realy to my Windows Based DHCP Server.  How do I enable DHCP Relay on the 3560?
Thanks!
Mark Berry
the ip helper command would be on your Layer 3 interface.  based on the output you are showing I suspect you are looking at a layer 2 interface.  for example a basic config might see something like this:
interface GigabitEthernet1/0/1
description L2 interface in vlan 10
switchport access vlan 10
switchport mode access
description L2 interface in vlan 11
interface Vlan10
description Data Vlan
ip address 10.10.10.254 255.255.255.0
interface Vlan11
description Data Vlan two
ip address 10.10.11.254 255.255.255.0
ip helper-address 10.10.10.10
also ensure ip routing is enabled on global config
8 Replies 8
dendazen2000
I think it is enabled by default.
Otherwise command:
#:config t
#:service dhcp
dendazen2000
Oh and surely, i forgot to add
you will have to configure ip helper-address "DHCP server IP" on the interface you want to relay.
Thank you for your reply.
But I don’t see a “ip helper-address option.
switch(config-if)#ip ? Shows only
access-group
arp
dhcp
igmp
verify
switch(config-if)#ip dhcp ? reveals only
snooping DHCP Snooping
interface Vlan10
interface Vlan11
That looks like it!  Thanks!
So to recap:
1.  Verify DCHP enabled globaly
2.  Set ip helper-address on the VLAN (Layer 3) interface that points to the DHCP server.
and that's it eh?
  If you  have your own dhcp server then all you need is the ip helper statement on any L3 interface that is not on the dhcp server subnet.
Had never heard the term "Layer Three Interface".  Just assumed that all "interfaces" on a L3 switch would be "layer 3 interfaces".  So are all "VLAN" interfaces considered "Layer 3 Interfaces" and the physical "ports/interfaces" are considered "layer 2 interfaces"?
   The answer is the ports can be either .  You can make the ports a "routed" L3  port where you put the ip address directly on the port itself  with the "no switchport"  command  or you can make the ports a layer 2 port with the "switchport" command and then if you want to route traffic on that port you would create a "SVI"  aka "interface vlan X   and assign those ports into the vlan .  It really depends on what you are trying to accomplish with the port or design considerations on how you set it up .
