DHCP Relay Problem
smavashev
Having a problem with 3550 Layer 3 Switch getting DHCP from 2800 Routers
Ths SVI's for layer 3/2 are working fine, and hosts are pinging.
Now my job is to get DHCP to work from 2800 to 3550 switch and in the end NAT translate it to the outside, When I configured DHCP on .3550 switch it worked  fine, I do not know how to relay the DHCP address to the 3550 switch. Help !!!
3550 Switch
interface vlan 20
ip address 192.168.1.0 255.255.255.0
ip helper-address 10.1.1.1
router eigrp 1
  network 10.1.1.1  255.255.255.252
  network 192.168.1.0 255.255.255.0
Router 2800
int fa0/0
ip address 10.1.1.2 255.255.255.252
ip dhcp excluded-address 192.168.1.1 192.168.10.10
ip dhcp pool 2800
   dns-server 167.206.245.129
   default-router 192.168.1.1 ***(gateway)
ip nat MY-NAT-POOL 67.85.96.231 netmask 255.255.255.0
ip nat inside source list NAT fa0/1 overload
ip access-list extended NAT
  permit ip 192.168.1.0 0.0.0.255 any
int fa0/1
ip address dhcp
router eigrp 1
network 67.85.96.231 netmask 255.255.255.0
Reza Sharifi
So, you are running EIGRP between the switch and the router?
Why do you have host network statement (10.1.1.1 255.255.255.252) under both router and switch EIGRP process?
If this is a /30 than it should look link this
10.1.1.0 255.255.255.252
Also,  do you have EIGRP peering between the router and the switch?
sh ip eigrp nei
