dhcp renewal rebinding
malshara
hello ,
I just need to know what is the Destination Mac address that should the client send in case renew lease for an IP address ?
6 Replies 6
acampbell
The client will send a dhcp requst packet as ip unicast to the server ip address.
The destibation MAC will either be the DHCP server if on the same Vlan or the clients default gateway
if the server is remote from the client subnet.
Alex
Regards, Alex. Please rate useful posts.
Hi Alex ,
thanks for your replay ,I have a relay in between so I should expect the mac address for the relay device,but what if the destination mac address is a broadcast ?
as far as I understand, DHCP differentiates between RENEWING (T1-Timer, by default 1/2 of total lease time) and REBINDING (T2 Timer expired, by default 7/8 of total lease time).
RFC 2131 4.3.6 Table 4:
|              |INIT-REBOOT  |SELECTING    |RENEWING     |REBINDING |
|broad/unicast |broadcast    |broadcast    |unicast      |broadcast |
|server-ip     |MUST NOT     |MUST         |MUST NOT     |MUST NOT  |
|requested-ip  |MUST         |MUST         |MUST NOT     |MUST NOT  |
|ciaddr        |zero         |zero         |IP address   |IP address|
Rolf
Hi Rolf,
this is the issue that I can see the destination mac address for the renew DHCP REQUEST as a broadcast and as my information ,it should be a unicast ,I need to understand what make a client to send the destination mac adress as a broadcast since he already has the information for the destination mac address and the ip address for the server .
here am talking about the renew process .
Well, it depends of course on the clients respective DHCP implementation.
The only standard-based explanation I found is this (4.4.4 Use of broadcast and unicast):
If the client receives no response to DHCP messages sent
to the IP address of a known DHCP server, the DHCP client
reverts to using the IP broadcast address.
Rolf
I will try to check again ,and get back to you soon ,hope with an explanation :) .
thanks for your assistance
