DHCP server redundancy between two core switches
1dilsarahm
I have a Windows DHCP server and two Cisco 3850 switches.
I need to achieve redundancy between the DHCP server and core switches in case of a failure of one core switch.
What should I configure to make DHCP server redundant?
Best regards,
Melanka
P.S - Sorry for my poor English :)
Seb Rupik
Hi there,
Lookup into NIC teaming with LACP for the version of MS that you are using. Assuming your 3850's are stacked together, configure a port-channel with a member link connected to each switch into your MS server/ ESXi host.
http://itprocentral.com/configuring-nic-teaming-using-lacp-in-windows-server-2016/
cheers,
Seb.
Mark Malone
You could leave it at layer 2 both links just use spanning tree cost on one of the links to make it less preferable spanning-tree cost 10000 , if the preferred link goes down the other path will kick in
if the switches are stacked , you could just use a port-channel lacp to the server
marce1000
 - Of course this could also be looked from the viewpoint of redundant DHCP services or else what if the
 DHCP server itself fails ? I am not commercially biased but as  a practical example I only mention that, on our Intranet,  we are using an Infoblox HA-pair in 2 separate data centers for redundant DHCP servicing (e.g.).
 M.
