DHCP Snooping and IP Source Guard
dankennedy
Hi. I need to configure DHCP snooping and IP source guard, but the DHCP server is not directly connected to the access layer, and is actually seperated by a layer three boundary.
The Topology is very simple
ACCESS LAYER > Routed Connection > SERVER SWITCH.
Can i still use DHCP snooping and if so where would it be configured?
Thanks in advance
Edison Ortiz
You should configure DHCP snooping in all switches in your network. The switchports facing the DHCP servers and other switches should be trusted switchports while all other switchports should be configured as untrusted.
Please see this link:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_37_se/configuration/guide/swdhcp82.html#wp1078853
HTH,
__
Edison.
