DHCP snooping blocks all dhcp traffic
harm.prins
I'm struggling with DHCP snooping, and I can't find any helpful information on the internet. So i hope someone here can help.
I'm configuring DHCP snooping, and (as far as i know), I've configured it according to the manual. But now my DHCP won't work anymore (DHCP request failed on end devices). When I disable DHCP snooping, everything works again.
Context: This all takes place in Packet Traces, on a 2960 switch
My config looks like this (all fastethernet ports are end devices, g0/1 is connected to the DHCP server via some other switches):
Building configuration...
Current configuration : 2970 bytes
version 15.0
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Sw-Zw-Office-1
ip dhcp snooping vlan 10,20,50,100,150
ip dhcp snooping
spanning-tree mode pvst
interface FastEthernet0/1
 switchport access vlan 10
 ip dhcp snooping limit rate 10
 switchport mode access
 switchport port-security
 switchport port-security mac-address sticky
 switchport port-security mac-address sticky 0060.3E05.7998
 spanning-tree portfast
 spanning-tree bpduguard enable
interface FastEthernet0/2
 switchport port-security mac-address sticky 0002.16BD.2461
interface FastEthernet0/3
 switchport access vlan 20
 switchport port-security mac-address sticky 0090.215B.1C3D
interface FastEthernet0/4
 switchport voice vlan 150
 switchport port-security maximum 3
 switchport port-security mac-address sticky 0001.C7C1.6B70
 switchport port-security mac-address sticky 0005.5E95.C343
 mls qos trust cos
interface FastEthernet0/5
 switchport port-security mac-address sticky 0060.5C17.69BC
interface FastEthernet0/6
 shutdown
interface FastEthernet0/7
 shutdown
interface FastEthernet0/8
 shutdown
interface FastEthernet0/9
 shutdown
interface FastEthernet0/10
 shutdown
interface FastEthernet0/11
 shutdown
interface FastEthernet0/12
 shutdown
interface FastEthernet0/13
 shutdown
interface FastEthernet0/14
 shutdown
interface FastEthernet0/15
 shutdown
interface FastEthernet0/16
 shutdown
interface FastEthernet0/17
 shutdown
interface FastEthernet0/18
 shutdown
interface FastEthernet0/19
 shutdown
interface FastEthernet0/20
 shutdown
interface FastEthernet0/21
 shutdown
interface FastEthernet0/22
 shutdown
interface FastEthernet0/23
 shutdown
interface FastEthernet0/24
 shutdown
interface GigabitEthernet0/1
 switchport trunk native vlan 100
 switchport trunk allowed vlan 10,20,50,100,150
 ip dhcp snooping trust
 switchport mode trunk
interface GigabitEthernet0/2
 shutdown
interface Vlan1
 no ip address
 shutdown
line con 0
line vty 0 4
 login
line vty 5 15
 login
end
Hello
Appy the following and test again:
no ip dhcp snooping information option
Kind Regards
Paul
follow
Hello
Kind Regards
Paul
Yeah that works! But why?
Thanks!
Hello
It all to do with a feature called option 82 which is enabled by default when dhcp snooping is enabled  this feature sends this option 82 towards the dhcp server and if the server dosent support it - it will not respond with an offer to the client - So you can tell the switch with snooping enabled not send dhcp discovery messages with this option so the dhcp server that doesn’t support it will reply with an offer
Kind Regards
Paul
