DHCP snooping etherchannel issue
Andy White
Level 3
Level 3
I have enabled IP DHCP snooping on 2 switches that are connetced to each other via an etherchannel using 2 ports.  On switch 1 it has the DHCP pool, but users on the 2nd switch couldn't get DHCP addresses eventough I added  the "ip dhcp snooping trust" command on both pots in the ehterchannel either side and the "no ip dhcp snooping information option".
What fixed it was adding the "ip dhcp snooping trust" commad on the port channel which I have never had to do before is this normal?
Rolf Fischer
Level 9
Level 9
Hi Andy,
in simple terms, DHCP snooping allows a (edge)port to receive DHCP client traffic, which is Discover, Request, Release, Inform.
Received DHCP server traffic like Offer and Ack is dropped by DHCP snooping by default in order to prevent from rogue DHCP servers, so the real serverport(s) and the uplinks as well have to be trusted in order to allow DHCP server traffic (as the uplinks receive client- and server traffic).
Rolf
Yes. When you do a "show mac address-table" you'll see that MAC-addresses are learned on the port-channel interface, no on the physical member-ports.
