DHCP Snooping Issue on Multiple Switches
PTP fellow admins. Need some advise on the attached set-up tested in PT.
Just to give a heads up, the design's goal is to implement security across the entire network by enabling dhcp snooping to address rogue dhcp server/s in a big enterprise compose of around 30-40 access switches for edge users and other connectivity requirements.
Setup:
1. Core Switch (3560 for simulation) as DHCP with inter vlan
2. 1 Distribution and multiple Access Switches for wired users and wireless APs.
3. Access switch having the dhcp snooping configurations
Issue: Upon enabling dhcp snooping on AS1, PC connected via VLAN 928 cannot acquire address.
DHCP snooping is enabled as well on DISTRI1 and workstations in AS2-AS5 are working normally having dynamic set up. This is just a portion of the entire network I'm planning to deploy the dhcp snooping configuration.
Is there a limitation for this set-up? Thank you very much in advance.
balaji.bandi
On high level the model of network you described should work as expected with DHCP snooping settings.
considering :
1. You have setup proper DHCP Scopes and Expluded IP's
2. correct Option 82 Options.
apart from above. since we do not know what is the configuration you have implemented in the access switches.
post show run to have looking, working v/s not working switch configs.
Please refer option82 document from cisco :
https://www.cisco.com/c/en/us/td/docs/wireless/controller/7-4/configuration/guides/consolidated/b_cg74_CONSOLIDATED/b_cg74_CONSOLIDATED_chapter_010110010.html
Also refer :  DHCP Relay configuration :
https://www.cisco.com/en/US/docs/ios/12_4t/ip_addr/configuration/guide/htdhcpre.html
BB
Thank you very much for the inputs. Anyhow, it's just a simple straight forward dhcp config and attached the running config of the core,distri and access for reference. No relevant configurations added in sir.
Hello
Please disable option 82 on the access switch and test again
no ip dhcp snooping information option
Also you dont need dhcp snooping applied on the distribution only the access layer, And you've only enable snooping for vlan 928 is that correct?
Kind Regards
Paul
