dhcp snooping issues with phone
carl_townshend
Hi all
I am having issues with my voip phone, it will not boot into the correct vlan, I get this on the port, all other ports are configured the same and phones the same also
DHCP_SNOOPING-5-DHCP_SNOOPING_NONZERO_GIADDR: DHCP_SNOOPING drop message with non-zero giaddr or option82 value on untrusted port, message type: DHCPDECLINE, MAC sa: 001a.e80a.0261
5 Replies 5
Reza Sharifi
Carl,
This is an informational message only. No action is required.
Error Message    DHCP_SNOOPING-5-DHCP_SNOOPING_NONZERO_GIADDR: [char] drop message
with non-zero giaddr or option82 value  on untrusted port message type: [char] MAC
sa: [mac-addr]
Explanation    The DHCP snooping feature discovered a DHCP packet with option values not allowed  on the untrusted port, indicating some host may be trying to act as a DHCP relay or server. The  packet will be dropped.
Recommended Action    This is an informational message only. No action is required.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/31sga/system/message/emsg.html
Ven Taylor
Level 4
Level 4
Can you share your switch port configuration?
Is the switch port configured with a voice vlan?
In a normal switchport configuration for a phone, you'll have a switchport access vlan and a switchport voice vlan.
Ven
Ven Taylor
lgrochal
Just came across the same issue with a Cat3750X and an Alcatel IPTouch phone. For whatever reason the phone didn't like the (perfectly good, for me) address provided by the DHCP server and kept sending back the
DHCPDECLINE messages with some additional options attached, which in turn made the switch drop the DECLINE packets. A stale-mate, of sorts.
I've managed to work around the issue by temporarily configuring the port as trusted ('ip dhcp snooping trust') and allowing the server and the phone to negotiate an addres more to the phones tastes. After that, everything works fine, with the trust removed ('no ip dhcp snooping trust') again.
Not much of a solution, but as this looks extremely rare (first time since I've implemented port-security and snooping in my infrastructure), I can live with it. And blame the phone.
Best regards,
Łukasz Grochal
esomarriba
Level 5
Level 5
Hi Carl,
Try the following best practice:
interface FastEthernet 0/X
description connection to user+phone
switchport mode access
switchport port-security maximum 5
switchport port-security aging time 5
switchport port-security aging static
switchport port-security aging type inactivity
switchport port-security violation protect
no snmp trap link-status
storm-control broadcast level 10.00
storm-control action shutdown
arp timeout 900
spanning-tree portfast
speed auto
duplex auto
auto qos voip cisco-phone
no shutdown
HTH,
/ES
Steven Peree
In our case we had the same error messages.
Turned out that we had CDP disabled on all access ports. And because cisco phone's rely on this for their configuration...
