DHCP Snooping on a trunk interface
Rodrigo Gurriti
Level 3
Level 3
Hello
I have the following set up on my network.
My problem is that i cannot get a DHCP address on the client.
I have the following config for both:
Global
ip dhcp snooping
ip dhcp snooping vlan 10 , 20 , 30
Interface trunk
switchport mode trunk
switchport trunk allow vlan 10,20,30
ip dhcp snooping trurst *only on the Client's switch
Thank you !
Ganesh Hariharan
Global
ip dhcp snooping
Interface trunk
Thank you !
To configure DHCP snooping just follow these steps
The first step to configure DHCP Snooping is to turn on DHCP snooping in all Cisco Switches using the “ip dhcp snooping” command.
All Cisco Switches (config)#ip dhcp snooping
Second step is to configure the trusted interfaces,
Switch(config)#interface range  gigabitEthernet 3/21 - 23
Switch (config-if)#ip dhcp snooping trust
Finally configure VLANS for DHCP snooping DHCP snooping will used on all the VLANs
Hope to Help !!
Ganesh.H
I've got working but only when i add the comand ip dhcp snooping trust to both trunking interfaces.... why is that ? should not it only need the trust command on the client's switch trunk ? Why does it need to be on both trunks? The servers switch only will forwared the DHCP packets to the client why does it need to be trusted ?
Thank you !
this explain quite well, mostly due to option82 enabled by default.
http://packetpushers.net/ccnp-studies-configuring-dhcp-snooping/
