IS GLBP SUPPORTED ON NEXUS 5500
mcg-tulsa
I am wondering if GLBP is supported on nexus 5500
I have 4 5548s I want to run glbp on but the feature is not listed to activate.
version 5.2(1)N1(1a)
I have features hsrp and vrrp but no glbp.  According to what I read from Cisco you don't need special licensing for it.  So why can I not activate the feature?
MCG-TUL-CORE01(config)# show feature  | grep glbp
glbp                  1         disabled
MCG-TUL-CORE01(config)# feature glbp
% Invalid command at '^' marker.
MCG-TUL-CORE01(config)# feature ?
  bgp             Enable/Disable Border Gateway Protocol (BGP)
  cts             Enable/Disable CTS
  dhcp            Enable/Disable DHCP Snooping
  dot1x           Enable/Disable dot1x
  eigrp           Enable/Disable Enhanced Interior Gateway Routing Protocol (EIGRP)
  fcoe            Enable/Disable FCoE/FC feature
  fcoe-npv        Enable/Disable FCoE NPV feature
  fex             Enable/Disable FEX
  flexlink        Enable/Disable Flexlink
  hsrp            Enable/Disable Hot Standby Router Protocol (HSRP)
  http-server     Enable/Disable http-server
  interface-vlan  Enable/Disable interface vlan
  lacp            Enable/Disable LACP
  msdp            Enable/Disable Multicast Source Discovery Protocol (MSDP)
  ntp             Enable/Disable NTP
  ospf            Enable/Disable Open Shortest Path First Protocol (OSPF)
  ospfv3          Enable/Disable Open Shortest Path First Version 3 Protocol (OSPFv3)
  pim             Enable/Disable Protocol Independent Multicast (PIM)
  port-security   Enable/Disable port-security
  private-vlan    Enable/Disable private-vlan
  privilege       Enable/Disable IOS type privilege level support
  ptp             Enable/Disable PTP
  rip             Enable/Disable Routing Information Protocol (RIP)
  ssh             Enable/Disable ssh
  tacacs+         Enable/Disable tacacs+
  telnet          Enable/Disable telnet
  udld            Enable/Disable UDLD
  vpc             Enable/Disable VPC (Virtual Port Channel)
  vrrp            Enable/Disable Virtual Router Redundancy Protocol (VRRP)
  vtp             Enable/Disable Vlan Trunking Protocol (VTP)
8 Replies 8
Reza Sharifi
5Ks do not support GLBP, only 7Ks do
this is a serious problem.
the documentation I am looking at from cisco.com shows 5500 having hsrp/glbp/vrrp support
Hello
GLBP is not currently supported on nexus 5000 platform
But currently there is a plan to support it in one of the future releases next year.
HTH,
Alex
Does anybody know if GLBP is now supported on the NEXUS5548UP.
If so, which release would be required to run GLBP.
Derrick
Hi Derrick,
GLBP is still not supported on Nexus 5500.
Nexus 5000 currently supports two First-Hop Redundancy Protocols - HSRP and VRRP. GLBP
support is not implemented on 5000 yet and any current releases.
Inayath
*Plz rate the usefull posts.
noc-cville
So this original post was written two years ago.  I'm wondering if GLBP has yet been implemented on the Nexus 5K's as I two have a need for it.  If not, any target date for it?  THis is becoming a problem.
Mark,
GLBP is not supported on N5K (but supported on N7K).
Currently, GLBP is not in N5K roadmap.
If you are using vPC, then both active and standby HSRP routers are forwarding packets so traffic is load balanced by L2 vPC port-channel hash.
http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/operations/n5k_L3_w_vpc_5500platform.html#wp998303
vPC and First Hop Redundancy Protocol
When you use a Cisco Nexus 5548 switch or Cisco Nexus 5596UP switch as a default gateway for hosts, you can deploy the First Hop Redundancy Protocol (FHRP) to provide default gateway redundancy. Beginning with Cisco NX-OS Release 5.0(3)N1(1b), an active FHRP peer and a standby peer can perform Layer 3 forwarding when you enable vPC. This optimization improves bandwidth, avoids sending the Layer 3 traffic over the vPC peer link, and requires no configuration or protocol change. Only the FHRP active peer answers ARP requests. Because both active and standby FHRP peers can forward Layer 3 traffic, you do not need to configure an aggressive timer for FHRP to provide faster failover and convergence time if an active FHRP peer fails.
Figure 3-1<http://www.cisco.com/en/US/docs/switches/datacenter/nexus5000/sw/operations/n5k_L3_w_vpc_5500platform.html#wp998349> shows that the Layer 3 traffic that originated from the host and is destined to a host several hops away can be routed by both the Host Standby Router Protocol (HSRP) active and the HSRP standby switch.
Inayath
*********Plz rate if this info is helpfull......
