DHCP snooping statistics
belal.sadozai
Does anyone know what is mean the field below :  Misdirected Packets
Switch#sh ip dhcp snooping statistics detail
Packets Processed by DHCP Snooping                    = 1212
Packets Dropped Because
   IDB not known                                        = 0
   Queue full                                               = 0
   Interface is in errdisabled                         = 0
   Rate limit exceeded                                = 0
   Received on untrusted ports                     = 0
   Nonzero giaddr                                        = 0
   Source mac not equal to chaddr               = 1
   No binding entry                                      = 0
   Insertion of opt82 fail                                = 0
   Unknown packet                                      = 0
   Interface Down                                         = 0
   Unknown output interface                          = 46
   Misdirected Packets                 = 50
   Packets with Invalid Size                           = 0
   Packets with Invalid Option                        = 0
Thanks in advance
5 Replies 5
shailesh.h
Misdirected
Number of packets that was dropped due to having an address that would have caused the packets to be punted.
http://www.cisco.com/en/US/partner/docs/ios/sbc/command/reference/sbc_01.html
With regards,
Shailesh
Nicholas Poole
Anybody got a correct answer on this as the only other pose was about CUBE which has nothing to do with DHCP SNOOPING?
I'am waiting to have more clear response for this
hello,
I'm searching for the same question .
Did you have some answers  about what these misdirected packets?
Thanx
I've notice the same in my network. I think it is due to the broadcast dhcp packets entering your trusted upstream server interface, originated in others switches belonging to the same vlan and without dhcp snooping enabled. This fact makes dhcp packets being broadcasted to every port and thus reaching other switches. I think if you configure dhcp snooping for your vlan in every swtich, with only upstream interfaces as trusted, you shouldn't see misdirected dropped packets anymore. I hope to test this in a few days.
Regards.
