DHCP snooping trust command info
mahesh18
Level 6
Level 6
Hi all,
I had layer 3 switches Providing DHCP to clients.
Users connect to access layer switch and that has trunk connection to layer 3.
Layer config
ip dhcp snooping
ip dhcp snooping vlan 20
Now layer 2 switch has no dhcp snooping config.
When user connects to layer 2 switch he gets the IP address.
On layer 3 switch i can see that dhcp snooing binding.
My question is  this right decesion if switch is providing the DHCP?
Second  question  is that it is working fine without marking any trust port on layer 2 or layer 3 switch?
MAhesh
Julio Carvajal
Hello Manesh,
That is one of the many designs.
The switch will act as the DHCP server and DHCP snooping database, that will mean all of it's ports will be on the untrusted state.
You should not have any issues.
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Julio Carvajal
Hello Manesh,
Julio
Julio Carvajal
