Difference between 1000-T and 1000-Tx
YUEN WAI NAM
Understand they are using dfferent cat cable. Does Cisco equipment nromally all are 1000-T, how to check they are 1000-T or 1000-Tx, does cat 5 with 4 pairs already support GE speed.
nkarthikeyan
Level 7
Level 7
Hi Yuen,
1000 Base T uses all the 4 pairs in both the directions simultaneously where in 1000 base Tx does that with only 2 pairs used for the two way communication... i.e. one pair for each direction
Cat 5 and advanced models supports 1000 base T.
Cat 6 and above supports 1000 Base Tx.
Refer the below wikipedia for more information.
http://en.wikipedia.org/wiki/Gigabit_Ethernet
Please do rate for the helpful posts.
By
Karthik
nkarthikeyan
Level 7
Level 7
Hi Yuen,
Thanks for your rating. Mark this as answered so that this will be helpful for others to find out in future.
By
Karthik
