Inactive interface on WS-C4507R+E
eleandroaraujo
Community Member
I have a switch WS-C4507R + E, added two SFP SFP-10GBase-SR, and they stayed with inactive status, would like some help to activate these interfaces in 10Gb.
Tks
Eleandro
SWC-DC01#sh interfaces status module 4
Port      Name               Status       Vlan       Duplex  Speed Type
Te4/1                        connected    trunk        full a-1000 1000BaseBX10-U
Te4/2                        notconnect   1              full   auto No XCVR
Te4/3                        inactive        220           full   auto 10GBase-SR
Te4/4                        inactive        220           full   auto 10GBase-SR
SWC-DC01#sh ver
Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.02.02.SG RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 07-Dec-11 19:55 by prod_rel_team
cisco WS-C4507R+E (MPC8572) processor (revision 😎 with 2097152K/20480K bytes of memory.
Processor board ID FOX1510H4QD
MPC8572 CPU at 1.5GHz, Supervisor 7
Last reset from Reload
15 Virtual Ethernet interfaces
96 Gigabit Ethernet interfaces
8 Ten Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
SWC-DC01#sh module
Chassis Type : WS-C4507R+E
Power consumed by backplane : 40 Watts
Mod Ports Card Type                              Model              Serial No.
1    48  10/100/1000BaseT (RJ45)                WS-X4648-RJ45-E    JAE15160DIT
2    48  10/100/1000BaseT (RJ45)                WS-X4648-RJ45-E    JAE15160DGE
3     4  Sup 7-E 10GE (SFP+), 1000BaseX (SFP)   WS-X45-SUP7-E      CAT1516L0G2
4     4  Sup 7-E 10GE (SFP+), 1000BaseX (SFP)   WS-X45-SUP7-E      CAT1516L0FU
SWC-DC01#sh inventory
NAME: "Linecard(slot 3)", DESCR: "Sup 7-E 10GE (SFP+), 1000BaseX (SFP) with 4 SFP+ Ports"
PID: WS-X45-SUP7-E     , VID: V01  , SN: CAT1516L0G2
NAME: "Linecard(slot 4)", DESCR: "Sup 7-E 10GE (SFP+), 1000BaseX (SFP) with 4 SFP+ Ports"
PID: WS-X45-SUP7-E     , VID: V01  , SN: CAT1516L0FU
NAME: "TenGigabitEthernet4/3", DESCR: "SFP-10Gbase-SR"
PID: SFP-10G-SR        , VID: V03  , SN: AGD162143P9
NAME: "TenGigabitEthernet4/4", DESCR: "SFP-10Gbase-SR"
PID: SFP-10G-SR        , VID: V03  , SN: AGD162143GN
SWC-DC01#sh run int te4/3
Building configuration...
Current configuration : 91 bytes
interface TenGigabitEthernet4/3
switchport access vlan 220
switchport mode access
end
SWC-DC01#sh run int te4/4
interface TenGigabitEthernet4/4
end
SWC-DC01#sh int te4/3
TenGigabitEthernet4/3 is down, line protocol is down (inactive)
  Hardware is Ten Gigabit Ethernet Port, address is 6400.f159.bdc6 (bia 6400.f159.bdc6)
  MTU 1500 bytes, BW 10000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, Auto-speed, link type is auto, media type is 10GBase-SR
  input flow-control is off, output flow-control is off
  Last input never, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts (0 multicasts)
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 1 interface resets
     0 lost carrier, 0 no carrier
SWC-DC01#sh int te4/4
TenGigabitEthernet4/4 is down, line protocol is down (inactive)
  Hardware is Ten Gigabit Ethernet Port, address is 6400.f159.bdc7 (bia 6400.f159.bdc7)
     0 output errors, 0 collisions, 2 interface resets
SWC-DC01#sh int te4/3 transceiver detail
ITU Channel not available (Wavelength not available),
Transceiver is internally calibrated.
mA: milliamperes, dBm: decibels (milliwatts), NA or N/A: not applicable.
++ : high alarm, +  : high warning, -  : low warning, -- : low alarm.
A2D readouts (if they differ), are reported in parentheses.
The threshold values are calibrated.
                              High Alarm  High Warn  Low Warn   Low Alarm
          Temperature         Threshold   Threshold  Threshold  Threshold
Port       (Celsius)          (Celsius)   (Celsius)  (Celsius)  (Celsius)
Te4/3       21.5                75.0        70.0         0.0       -5.0
           Voltage            Threshold   Threshold  Threshold  Threshold
Port       (Volts)            (Volts)     (Volts)    (Volts)    (Volts)
Te4/3      3.26                  3.60        3.50        3.10       3.00
           Optical            High Alarm  High Warn  Low Warn   Low Alarm
           Transmit Power     Threshold   Threshold  Threshold  Threshold
Port       (dBm)              (dBm)       (dBm)      (dBm)      (dBm)
Te4/3      -40.0                 1.6        -1.3        -7.3      -11.3
           Receive Power      Threshold   Threshold  Threshold  Threshold
Te4/3      -40.0                 1.9        -1.0        -9.9      -13.9
SWC-DC01#sh int te4/4 transceiver detail
Te4/4       23.2                75.0        70.0         0.0       -5.0
Te4/4      3.29                  3.60        3.50        3.10       3.00
Te4/4      -40.0                 1.6        -1.3        -7.3      -11.3
Te4/4       -4.8                 1.9        -1.0        -9.9      -13.9
SWC-DC01#sh int te4/3 capabilities
  Model:                 WS-X45-SUP7-E-Gbic
  Type:                  10GBase-SR
  Speed:                 1000,10000
  Duplex:                full
  Auto-MDIX:             no
  EEE:                   no
  Trunk encap. type:     802.1Q
  Trunk mode:            on,off,desirable,nonegotiate
  Channel:               yes
  Broadcast suppression: percentage(0-100), hw
  Multicast suppression: percentage(0-100), hw
  Flowcontrol:           rx-(off,on,desired),tx-(off,on,desired)
  VLAN Membership:       static, dynamic
  Fast Start:            yes
  CoS rewrite:           yes
  ToS rewrite:           yes
  Inline power:          no
  SPAN:                  source/destination
  UDLD:                  yes
  Link Debounce:         yes
  Link Debounce Time:    yes
  Port Security:         yes
  Dot1x:                 yes
  Maximum MTU:           9198 bytes (Jumbo Frames)
  Multiple Media Types:  no
  Diagnostic Monitoring: yes
SWC-DC01#sh int te4/4 capabilities
  Type:                  10GBase-SR
  Speed:                 1000,10000
  Duplex:                full
  Auto-MDIX:             no
  EEE:                   no
  Channel:               yes
  Fast Start:            yes
  CoS rewrite:           yes
  ToS rewrite:           yes
  Inline power:          no
  UDLD:                  yes
  Link Debounce:         yes
  Port Security:         yes
  Dot1x:                 yes
SWC-DC01#sh redundancy
Redundant System Information :
       Available system uptime = 11 weeks, 6 days, 4 hours, 46 minutes
Switchovers system experienced = 1
              Standby failures = 0
        Last switchover reason = active unit failed
                 Hardware Mode = Duplex
    Configured Redundancy Mode = Stateful Switchover
     Operating Redundancy Mode = Stateful Switchover
              Maintenance Mode = Disabled
                Communications = Up
Current Processor Information :
               Active Location = slot 3
        Current Software state = ACTIVE
       Uptime in current state = 11 weeks, 6 days, 4 hours, 46 minutes
                 Image Version = Cisco IOS Software, IOS-XE Software, Catalyst 4500 L3 Switch Software (cat4500e-UNIVERSALK9-M), Version 03.02.02.SG RELEASE SOFTWARE (fc3)
               BOOT = bootflash:cat4500e-universalk9.SPA.03.02.02.SG.150-2.SG2.bin,1;
        Configuration register = 0x2102
Peer Processor Information :
              Standby Location = slot 4
        Current Software state = STANDBY HOT
       Uptime in current state = 4 weeks, 4 days, 21 hours, 58 minutes
eleandroaraujo
Community Member
(SOLVED)
I found the problem that occurred was using ports 3 and 4 as Cisco documentation in supervisory operating in redundant mode, ports 3 and 4 are inactivated. After changing to ports 1 and 2 were functioning without the need for custom configuration for 10Gb bandwith.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/3.1.1SG/configuration/guide/sw_int.pdf
See 7-10
Limitation and Restriction on Supervisor Engine 7-E and Supervisor Engine 7L-E
Please note the following:
• When you use WS-X45-SUP-7-E in RPR or SSO mode, only the first two uplinks on each supervisor
engine are available. The second two uplinks are unavailable.
Selecting the Uplink Port on a Supervisor Engine 7L-E
Supervisor Engine 7L-E (WS-X45-SUP-7L-E) has two uplink modes: One-Gigabit and Ten-Gigabit.
The number of uplink ports now depends on the supervisor engine mode (single or redundandant) and
the uplink mode configuration (1-Gigabit or 10-Gigabit). To configure the uplink mode, use the
hw-module uplink select [gigabitethernet/ tengigabitethernet] command, as follows:
Switch(config)# hw-module uplink select ?
  gigabitethernet     Select the gigabit uplinks
  tengigabitethernet  Select the 10G uplinks
Note Supervisor Engine 7L-E  is not supported on a ten-slot chassis. USB device and SD card support is
applicable to both Supervisor Engine 7-E and Supervisor Engine 7L-E.
In general, observe the following:
• In Redundant Supervisor Mode, ports 3 and 4 on both supervisor engines are not usable.
• The total bandwidth of the connections on a Supervisor Engine 7-E is less than 48Gbps.
Tks for all!
