Difference between 9200 and 9200L
vban
We are migrating from a 2960 to a 9200L switch.
Will there be any difference between the 9200 and 9200L configuration?
How to start with the configuration and setup?
M02@rt37
Hello @vban
9200L is the fixed uplink model (uplinks are non-modular).
On the other hand, 9200 has modular uplinks, allowing different network modules.
https://www.cisco.com/c/en/us/products/collateral/switches/catalyst-9200-series-switches/nb-06-cat9200-ser-data-sheet-cte-en.html
Also, migrating from a c2960 to a 9200L (or 9200) switch should be straightforward.
Best regards
M02@rt37
Hello @vban
Best regards
How should I start the process for 9200L from 2960?
Enter the 2960 config into the 9200/9200L one line at a time until it stops due to incorrect configuration.  Investigate why and continue.
Joseph W. Doherty
You may run into some differences, especially if you're running a particularly old IOS version on the 2960.
@Leo Laohoo suggestion is good.
What I personally also like to do, is use a diff comparison tool between the old config and the new config and be able to account for any differences.
