Difference between FP and LP
subarayarsooper
Level 3
Level 3
what is the difference between the P, LP, FP of Poe switches is only the power or only half of the ports work as PoE ?
Ryan_Miles
Meraki Employee All-Star
Exactly as Brash stated. The PoE budget values are all listed in this doc. https://meraki.cisco.com/product-collateral/ms-family-datasheet/?file
Brash
Meraki Community All-Star
The difference is the total amount of available PoE power. You can verify the PoE power differences in the spec sheet
Ryan_Miles
