Difference between LAN Base, IP Base, and Enterprise IOS
praetoleiad
Can you give light on this?
What are differnces between these three IOS'? I have read differences between IP Base and Ent. IOS. Does LAN Base IOS 4500-E switch doesn't Layer 3 routing capability?
Lei Tian
You can think LAN base is subset of IP Base, and IP Base is subset of Enterprise. LAN base is L2 only; IP Base supports basic L3 function; enterprise supports all L3 functions.
HTH,
Lei Tian
Thank you sir for the prompt response to the query. Now it's been clear to me.
You are welcome.
Please consider rate helpful posts and you can help Haiti.
http://www.youtube.com/watch?v=gb8E7mvVVrs&feature=player_embedded
