Difference between WS-C3560G-48TS-S & WS-C3560V2-48TS-S
cisco
Hi ,
Any one if any idea what's the difference between WS-C3560G-48TS-S & WS-C3560V2-48TS-S. I have to suggest the better of these two w.r.t value for money ,to client. Please help.
regards
Neo
Somasundaram Jayaraman
++ The Cisco Catalyst  3560 v2 Series are next-generation, energy-efficient, Layer 3 Fast  Ethernet switches. These new switches support Cisco EnergyWise technology,  which helps companies manage power consumption of the network  infrastructure and network-attached devices, thereby reducing their  energy costs and their carbon footprint.
++ The new switches consume less power than  their predecessors and are ideal access layer switches for enterprise,  retail, and branch-office environments. They help you maximize  productivity and provide investment protection by enabling a unified  network for data, voice, and video.
The best way to compare a product is to refer the datasheets of those products.
3560V2:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/at_a_glance_c45-527653.pdf
http://www.cisco.com/en/US/products/hw/switches/ps5528/index.html
3560G:
WS-C3560G-48TS-S
• 48 Ethernet 10/100/1000 ports and 4 SFP-based Gigabit Ethernet ports
• 1RU fixed-configuration, multilayer switch
• Enterprise-class intelligent services delivered to the network edge
• IP Base software feature set (IPB)
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/product_data_sheet09186a00801f3d7d.html
The latest one is the 3560V2 switches.
Hope this helps
Cheers
Somu
Rate helpful posts
Leo Laohoo
The main difference between the plain and "V2" is the power consumption.  V2 uses less power than the older model.
Currently, I'd recommend using the V2 over the plain one.
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information  contained within this    posting without consideration and with the  reader's understanding  that   there's no implied or expressed suitability  or fitness for any   purpose.  Information provided is for informational  purposes only and   should not  be construed as rendering professional  advice of any kind.   Usage of  this posting's information is solely at  reader's own risk.
Liability Disclaimer
In     no event shall Author be liable for any damages whatsoever   (including,   without limitation, damages for loss of use, data or   profit) arising  out  of the use or inability to use the posting's   information even if  Author  has been advised of the possibility of  such  damage.
Posting
One notable difference, V2 series provide 10/100 copper ports, the 3560G series provides 10/100/1000 copper ports.
andtoth
Level 4
Level 4
Please refer to the Data Sheet for the mentioned switches below for more details.
Cisco Catalyst 3560 Series Switches Data Sheet
Cisco Catalyst 3560 v2 Series Switches
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/data_sheet_c78-530976.html
Best regards,
Andras
