Difference between WS-X4306 and WS-X4306-GB
p-miranda
I have found two line cards with this description installed in a Catalyst WS-4507R with Sup II+ (WS-X4013+):
WS-X4306 : 1000Base X (GBIC)
WS-X4306-GB: 1000Base X (GBIC)
Whats the difference between these modules? I cannot find information about part number "WS-X4306"
Do these modules (WS-X4306 and WSX4306-GB) work with SUP7-E ?
Thanks for your support.
Pedro
Reza Sharifi
Pedro,
These modules are the same.  Also, it is supported in the none-e chassis:
WS-X4306-GB: Cisco Catalyst 4500 Gigabit Ethernet Module, 6 ports (GBIC)
have a look:
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps4324/data_sheet_c78-612364_ps2797_Products_Data_Sheet.html
