Router's LAN facing interface becomes up/down frequently
gauravshar
Level 2
Level 2
Hi there,
We have a 1841 Cisco router for one of our remote sites and we have the GRE over IPSec tunnel on it (with our datacenter router) for the connectivity. The LAN facing interface becomes UP/Down (status 'UP', Protocol 'Down'). When I login the router and 'shut' and then 'no shut' the interface, the interface becomes UP and everything starts to work. Traffic starts to flow across it. But after some time, some hours or sometimes some days, the interface is again back to up/down status. The router is connected to  a non-Cisco switch. I do see some CRC's increasing very slowly, but apart from that there seems nothing wrong with the interface in sho int fas0/0 command:
RTR01#sho int fas0/0
FastEthernet0/0 is up, line protocol is down
  Hardware is Gt96k FE, address is 0026.cb91.ee48 (bia 0026.cb91.ee48)
  Description: $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
  Internet address is 10.74.57.1/24
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:07:47, output 00:07:47, output hang never
  Last clearing of "show interface" counters 01:52:43
  Input queue: 0/75/20417/0 (size/max/drops/flushes); Total output drops: 0
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 16000 bits/sec, 39 packets/sec
     979983 packets input, 93907374 bytes
     Received 927358 broadcasts, 0 runts, 0 giants, 0 throttles
     261 input errors, 261 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog
     142760 packets output, 20987130 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 lost carrier, 0 no carrier
The cofiguration on the interface is just : speed 100, dup full, the IP address and the helper-addresses..  Could it be because of any bug..
Leo Laohoo
Try swapping out the LAN cable.
You have CRC errors.  Ensure your speed and duplex setting are "auto".
