differences between 4507 and 6509
erivera5683
About a year ago we needed to upgrade the supervisors in our 6509 we also needed to have more than 2 scan sessions. We replaced it with a 4507. Now I need to tell management how this 4507 has improved our network.  Things such as backplane speed, etc. Im not sure where I can find this information.
mvsheik123
Level 7
Level 7
Check the 4500 and 6500 switches datasheets on Cisco website. The datasheet should give you technical details for that model.
hth
MS
Thanks I will look at that
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
As the other poster noted, datasheets should provide the details you need.  Do know though that supervisors, line cards and even the chassis have differences (within the 4500 or 6500 series) and overall capacity depends much on the combination of the different components.  I.e. it can be complex to compare a 6500 against another 6500 without even comparing a 4500 vs. a 6500.
thanks for responding, I will take a look at the datasheets
