Showing results forĀ
Search instead forĀ
Did you mean:Ā
hrsp arp issue
Hi ,
I have  vlan 5 with ip address 192.168.5.1 and standby(hrsp) ip address of 192.168.5.254. All users use 192.168.5.254 as default gateway.
I see lot of arp for 192.168.5.1 not 192.168.5.254 when using sniffing tool, is this normal?
devils_advocate
Level 7
Level 7
Yes its normal.
Some things need to know the physical address of the interface.
devils_advocate
Level 7
Level 7
Yes its normal.
but those arp come from  users vlan, e.g 192.168.5.42.
Do your interfaces (the ones in the standby groups) have IP Helper Addresses?
