Differences between WIC modules and Network modules (NM)
sawquecisco
Hello
I am reading this link: http://www.packettracernetwork.com/cisco-wic-modules.html
I understand that cisco devices' cards are splitted 2  sections: One of them is WIC module the other one is Network Module.
But what are the differences between them? I don't understand that.
For example; HWIC-4ESW has ethernet ports but also NM-1E or NM-1FE-TX etc has ethernet ports, so why is one of them under WIC Modules section, the others are under NM section?
Same as; NM-4A/S has serial ports, but also WIC-1T or WIC-2T has serial ports,
So what are the reasons of grouping cards into 2 sections, what are the criterias?
Thanks...
hobbe
Level 7
Level 7
To make things easy and simplified (ie not true but close enough)
First there where NM and WIC.
They evolved into NME and HWIC
NM = the network module
This is a big module that can hold a variaty of ports and also some NM modules have space and connectors for WIC cards.
WIC/HWIC smaller cards that can be inserted in a router or in some NM card.
WIC/HWIC cards are normally used in smaller router such as the 1900/1800/1700 type of routers.
The NM modules are normally used in the "bigger" routers such as the 2600/2800/2900 or above.
where they can also be used to enable the use of WIC/HWIC cards. togeather with the wic/hwic places that are already there.
If you look at the back of a 2811.
http://www.cisco.com/en/US/products/ps5881/index.html
Click on the 3d model and spin out things and check out modules
You can see the NME and the HWIC ports.
The NME have a lot more Ethernet ports than a HWIC can hold, just simply by the space they occupy,
Good luck
hobbe
Level 7
Level 7
Good luck
