02-04-2020 04:58 AM
Hello for everybody.
We have cat 9500 with ip management 192.168.100.2/24 and ip default-gateway 192.168.100.1. Unfortunately, there is no connection to external inet from this interface. Especifically for this purpose, i created another interface 192.168.101.2, which has Internet access. Is this possible to use this interface for connection to tools.cisco.com for activation dna license?
int vlan 2 192.168.101.2/24
maybe im wrong, but this should be smt like
ip http client source-interface Vlan2
02-04-2020 09:06 AM
02-04-2020 11:50 AM
from my switch
mps-9500-core#sh ip int br | i Vlan
Vlan1 192.168.100.2 YES NVRAM up up
Vlan2 192.168.101.2 YES manual up up
mps-9500-core#sh run | i ip default-gateway
mps-9500-core#ping 8.8.8.8
Sending 5, 100-byte ICMP Echos to 8.8.8.8, timeout is 2 seconds:
Success rate is 0 percent (0/5)
mps-9500-core#ping 8.8.8.8 source vlan 2
Packet sent with a source address of 192.168.101.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 17/17/18 ms
mps-9500-core#
02-04-2020 11:32 PM - edited 02-04-2020 11:38 PM
and i have question about smt like "lookup of cli".
Success rate is 100 percent (5/5), round-trip min/avg/max = 19/19/20 ms
mps-9500-core#ping tools.cisco.com source vlan 2
% Invalid input detected at '^' marker.
mps-9500-core#
Is this possible to fix it? Maybe i should select dns server for vlan 2 only?
If i understood correctly, its - ip name-server 4.2.2.2 8.8.8.8 for example, but for vlan 2 only...
02-05-2020 04:19 AM
02-05-2020 11:20 AM
this is possible commands
mps-9500-core#conf t
Enter configuration commands, one per line. End with CNTL/Z.
mps-9500-core(config)#ip dn?
dns
mps-9500-core(config)#ip dns s?
server spoofing
mps-9500-core(config)#ip dns ?
name-list Regular expression name-list
primary Configure primary DNS server
server Enable DNS server
spoofing Configure DNS spoofing
view Configure a DNS view
view-list Configure a DNS view-list
mps-9500-core(config)#ip dns se
mps-9500-core(config)#ip dns server ?
queue Configure queue parameters
view-group Configure a DNS view-list for global use on this system
<cr> <cr>
mps-9500-core(config)#dn
mps-9500-core(config)#dn?
% Unrecognized command
mps-9500-core(config)#na
mps-9500-core#na?
name-connection
mps-9500-core#ip dn
mps-9500-core#ip dn?
mps-9500-core#
02-06-2020 01:26 AM
02-06-2020 12:08 PM
I can try to change default-gateway. But can this switch ping any node by name, not only by ip.
For example ping tools.cisco.com and ping 72.163.4.38.
