05-01-2007 09:37 AM - edited 03-05-2019 03:47 PM
I have a quick question. Very basic. I have cisco 7206 and on FastEthernet which connects with Alcaltel switch can i configure two different ip subnets on an Interface.
Example :
cisco 7206
interface FastEthernet0/0
ip address 20.20.20.125 255.255.255.128 secondary
ip address 10.10.10.189 255.255.255.128
Now i have servers connected on different ports on the switch. Different subnets would be in different vlan. These are Alcatel switches so not sure what needs to be done on the switches.
But from the router perspective do i need to do anything.
Hassan...
Solved! Go to Solution.
05-01-2007 09:52 AM
Secondary IP addresses only work when both subnets are on the same VLAN. If you will have them on 2 VLANs on the switch, you'll need to set up a trunk between the Alcatel and the 7206 and configure it something like this:
description hosts on vlan 1 (native VLAN)
interface FastEthernet0/0.1
description hosts on Vlan 2
encapsulation dot1q 2
05-01-2007 10:02 AM
Hi Hassan,
Yes you are done with the configs on router. If you have differents IPs on same vlan you have to configure the way you described in your initial post.
Ankur
05-01-2007 09:52 AM
05-01-2007 09:58 AM
Thanks for the input. If different Ip's are on the same VLAN #, then all need to do is configure the way i described above ...right ??.I was just wondering if there is something extra i need to do.
Yes, you are right for different subnets on different vlans would need trunking..enaled to carry vlans on it.
Hassan
05-01-2007 10:02 AM
Hi Hassan,
Ankur
