03-06-2017 04:29 AM - edited 03-08-2019 09:37 AM
iam created the different switches having the same subnet
SW1(vlan 10)=====SW2-- (vlan 20)pc2( vlan 20) sw mo access
PC1(vlan 10) sw mode access
they are pinging
but how they are pinging with different vlans
please explain anyone they are different access ports
03-06-2017 06:02 AM
Yes if you are connecting 2 switches with ports over different vlan you will be able to ping each other it is because the frame are sent an untagged. But this scheme is not scalable. The vlan id is local for each switch unless you are doing propagation as VTP does. You could have some CDP problems but it will work fine.
03-06-2017 09:40 PM
here different vlans means different networks,if different networks communicate only by routing or intervlan routing
how pc1 communicate with pc2
03-07-2017 03:55 AM
If they are same subnets but in different vlans it could work:
SW1
interface vlan 10
ip add 192.168.1.1 255.255.255.0
interface fa0/1
P2P-to-SW2
switchport access vlan 10
SW2
interface vlan 20
ip add 192.168.1.2 255.255.255.0
interface fa0/1
description P2P-to-SW1
switchport access vlan 20
but as you mentioned they are different subnets, it could work if you are using secondary networks or if the switch is a layer 3 device with ip routing command line enabled.
Example:
SW2
interface vlan 20
ip add 2.2.2.2 255.255.255.255 secondary
interface fa0/1
Could you please share the model of switch and the configuration?
03-06-2017 09:43 AM
Hello!
When a frame do not cross a trunk port it is not encapsulated with the vlan tag, so If you has configured that ports they can have conecction.
------PD: Do not forget to rate useful post-----
