Difficulty using CSMP CLI Tool with IR509.
I have been hoping to use the CSMP CLI Tool (https://ciscomarketing.jiveon.com/docs/DOC-53822) with an IR509. Before the CLI Tool can be used, a pppd connection must be made between the computer and the IR509 (https://communities.cisco.com/docs/DOC-53818). I'm using a Cisco serial to Ethernet cable, and am able to get some communication. If I use the command recommended in the document (pppd nodetach debug nocdtrcts noip ipv6 ::2 /dev/ttyS0 115200) the terminal freezes and I have to kill the PID. However, when I enter the command: sudo pppd nodetach debug nocdtrcts noip local /dev/ttyS0 115200 noauth, I seem to get some communication as seen in the attached output.
Any ideas on what I am doing wrong? Apologies if there is a more ideal forum to post in than here. I looked through the forums and subforums but did not see an ideal forum to post this.
Thank you for your time!
0 Replies 0
