Disable 3850 Integrated Wireless
thefilmguy
Is there a a way to disable the integrated wireless on the 3850 switches? Or is there a way to prevent them from showing up in Cisco Prime?
Mark Malone
Hi wireless is actually disabled  by default on 3850, if its on use this command to turn it off
no wireless mobility controller
If you want to block it from Prime can you not remove the Prime host ip from the acl thats allowing traffic in on the 3850 , Prime uses ssh. Block the ip it won't be able to collect anything from the switch
Mark Malone
Is there a way to physically disable it?
